Beans
Re: SDFtool Flasher
Post by Beans » Thu Jan 21, 2021 9:41 am
Hi, this is the image from the top of the drive
Re: SDFtool Flasher
Post by Billycar11 » Thu Jan 21, 2021 1:43 pm
Beans wrote: Thu Jan 21, 2021 9:41 am Hi, this is the image from the top of the drive
Strange should have worked this is why I recommend the one step flash process not 2 steps like you did less chance of something going wrong should have flashed directly to WH16NS60 1.02mk just return it and get another.
Looks beat up for a new drive anyway on the sticker
Beans
Re: SDFtool Flasher
Post by Beans » Thu Jan 21, 2021 3:04 pm
Is it worth me trying the Recover option in SDFtool?
If I consider returning it, is there a way that I can make the drive look like I've not tried to flash the firmware?
i.e. Can I flash with the original 1.05 firmware and if so, where can I get the correct file?
I wish I had tested a non UHD drive before attempting to flash it, as there's always the possibility that the drive wasn't working to begin with.
Beans
Re: SDFtool Flasher
Post by Beans » Thu Jan 21, 2021 4:51 pm
I've now tried updating with the official firmware update from the LG website, but I get this message.
Should I use SDFtool to flash with one of the old files, such as
mk-firmware-pack-20200720\MK\old\HL-DT-ST-BD-RE_WH14NS40-NS50-1.03-NM00600-211711211658.bin ??
Re: SDFtool Flasher
Post by Billycar11 » Thu Jan 21, 2021 10:34 pm
Beans wrote: Thu Jan 21, 2021 4:51 pm I've now tried updating with the official firmware update from the LG website, but I get this message.
Don't even worry about it they don't check
aboulfad
Re: SDFtool Flasher
Post by aboulfad » Fri Jan 22, 2021 12:51 am
@beans if amazon UK return policy is similar to US/CA, then it’s no issue to return. I just returned the ASUS and got instead the LG WH16NS40. Details of firmware used are in this earlier post.
The LG seems quieter and more reliable than the other ASUS, at least in my experience.
autofire
Re: SDFtool Flasher
Post by autofire » Sun Jan 24, 2021 11:41 pm
Help! I'm trying to rescue an early model WH16NS40 that got stuck on official firmware 1.05, but I can't find the appropriate firmware file to begin the process, and FirmwareExtractor fails on the WH16NS40_1.05.exe installer from LG.
Re: SDFtool Flasher
Post by Billycar11 » Mon Jan 25, 2021 2:21 am
autofire wrote: Sun Jan 24, 2021 11:41 pm Help! I'm trying to rescue an early model WH16NS40 that got stuck on official firmware 1.05, but I can't find the appropriate firmware file to begin the process, and FirmwareExtractor fails on the WH16NS40_1.05.exe installer from LG.
i just did this with another guy just follow this:
https://www.makemkv.com/forum/viewtopic ... 15#p104021
autofire
Re: SDFtool Flasher
Post by autofire » Mon Jan 25, 2021 4:59 pm
Billycar11 wrote: Mon Jan 25, 2021 2:21 am
No can do - my mobo isn't compatible with IDE, so dosflash is not an option...
Re: SDFtool Flasher
Post by Billycar11 » Mon Jan 25, 2021 10:17 pm
autofire wrote: Mon Jan 25, 2021 4:59 pm
Well sorry man if sdf tool is not working and you can't do dos flash your done for.
Unless you want to send it to one of us drive flashers but it's not worth it just buy a new drive
chang69
Re: SDFtool Flasher
Post by chang69 » Mon Jan 25, 2021 10:43 pm
MartyMcNuts wrote: Tue Aug 18, 2020 1:39 am Hi everyone,
I have created a windows GUI for the MakeMKV sdftool command line flasher. The appearance (and use) is similar to the modifed ASUS flasher, which should make it a bit easier for those that are unsure about using the command line. The latest is version 1.2.0.
Hi Marty, I just registered to say thank you.
I have side loaded my BH16NS55 1.05 to BH16NS50 and then upgraded to DE_WH16NS60 1.00. Work like a charm. :-)
Thanks again. Now I am going to het MakeMKV.
Re: SDFtool Flasher
Post by MartyMcNuts » Mon Jan 25, 2021 11:18 pm
chang69 wrote: Mon Jan 25, 2021 10:43 pm
Awesome! and you're welcome!!
Enjoy!
necrogeddon
Re: BH16NS40 1.05 recovered
Post by necrogeddon » Thu Jan 28, 2021 4:56 am
Wlassek wrote: Thu Jan 14, 2021 9:16 am Thanks for all. My problems (no disc detected in my BH16NS40 with latest 1.05 FW) seems to be solved by DosFlash32 which was included in USB recovery ISO (boot from flash to Win etc.). Many thanks. Now I´m on 1.03 FW and all seems to be ok. Thanks again and have a nice day :wink:
Hey bud I got the exact same problem as you had doing the same thing, I update innocently to official 1.05 from 1.03. It's been 4 days trying EVERYTHING including voodoo and black magic to no avail. Last chance is the DotFlash32 which i didnt check yet cos I need to install somewhere a x86 copy of win 10. My question is, which bin did you use to go back to 1.03? Many thanks
EncryptedEggs
Re: SDFtool Flasher
Post by EncryptedEggs » Fri Jan 29, 2021 9:43 pm
Ok trying now to figure out which firmware I should choose for my WH16NS40. I have the mk-firmware-pack-20200720 downloaded.
EncryptedEggs
Re: SDFtool Flasher
Post by EncryptedEggs » Fri Jan 29, 2021 11:54 pm
Ok I saw viewtopic.php?f=16&t=19634&start=540#p103656 and used HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936. Works like a charm now! Thanks all.
