glc650
#4306 Post by glc650 » Wed Jan 27, 2021 8:36 pm
morbius wrote: Wed Jan 27, 2021 8:13 pm one further quick question: does it make any difference if I output ts or m2ts from tsmuxer, with the X700 as the playback device?
I never tried always used m2ts since that is the container found on BR disc anyway. I would go with X800M2 at this point (unless you don't have good wifi 5 signal where the player will go).
glc650
#4307 Post by glc650 » Wed Jan 27, 2021 8:38 pm
lexyz wrote: Wed Jan 27, 2021 8:32 pm Driveless chinese oppo clone named M9702 or similar could be more interesting compared to X800M2
1Gbps LAN
BDMV folders over network with working Blu-ray menu
HDR10/DV/HDR10+
If only the price wasn't outrageous. Or if the firmware was still being updated might be worth it at the current price.
morbius
#4308 Post by morbius » Wed Jan 27, 2021 8:46 pm
thanks for advice. My one other question is whether forced subs get handled automatically via the m2ts method played in to the X700/X800. If not, that's a bit of a chore. All my mkv's are correctly tagged for forced subs, so Kodi/Plex pull them up seamlessly.
EDIT: if the X700/X800 plays a full-disc backup folder off a local USB drive [does it?], I have full virtual disc capability?
glc650
#4309 Post by glc650 » Wed Jan 27, 2021 9:04 pm
morbius wrote: Wed Jan 27, 2021 8:46 pm thanks for advice. My one other question is whether forced subs get handled automatically via the m2ts method played in to the X700/X800. If not, that's a bit of a chore. All my mkv's are correctly tagged for forced subs, so Kodi/Plex pull them up seamlessly.
X800 is not the same as X800M2. I believe the X800 (non-m2) only does HDR10. I don't recall what happens with forced subs but I think that depends on if the move has forced hard coded. If not you might have to select the forced track. I don't believe these players support BDMV backups (I know they don't over the network) at all (so m2ts/ts only).
#4310 Post by RESET_9999 » Wed Jan 27, 2021 9:11 pm
forced flags don't work on the x700.. you have to manually activate the subtitles.
morbius
#4311 Post by morbius » Wed Jan 27, 2021 9:14 pm
if the X700/X800(M2) played BDMV from USB that would be useful for me. I came across one positive reference to that via a search, but I guess there are some owners on this forum who may be able to confirm.
#4312 Post by shawnc22 » Wed Jan 27, 2021 9:16 pm
morbius wrote: Wed Jan 27, 2021 9:14 pm if the X700/X800(M2) played BDMV from USB that would be useful for me. I came across one positive reference to that via a search, but I guess there are some owners on this forum who may be able to confirm.
Pretty sure that's a no.
#4313 Post by RESET_9999 » Wed Jan 27, 2021 9:20 pm
DV is supported only in TS / M2TS / MP4 and bluray disc on the x700...
no BDMV support via USB
morbius
#4314 Post by morbius » Wed Jan 27, 2021 9:24 pm
thanks for clarifying. And it looks like I'll be stuck with selecting a forced/default sub track manually? So many films have these. In any event, it will be useful for me to have a DV-capable disc player to give me a reference for playback from other sources.
XTrojan
#4315 Post by XTrojan » Wed Jan 27, 2021 10:00 pm
On the LG CX internal player, what is supported with Dolby Vision playback?
I red some TsMuxer remuxes with AC-3 Audio is working and it's FEL, anyone can confirm this?
deadchip12
#4316 Post by deadchip12 » Thu Jan 28, 2021 2:33 am
RESET_9999 wrote: Wed Jan 27, 2021 9:20 pm
I notice that some films are divided into multiple m2ts files. What should we do in that case? What's the good way to identify which m2ts files are part of the film? And then we just drag all those files into tsmuxer and click m2ts muxing?
#4317 Post by RESET_9999 » Thu Jan 28, 2021 3:22 am
deadchip12 wrote: Thu Jan 28, 2021 2:33 am
add in tsmuxer the .mpls file of the main movie from the playlist folder.
in order to find out the correct playlist, you can use makemkv, mkvtoolnix, bdinfo etc.. .
lexyz
#4318 Post by lexyz » Thu Jan 28, 2021 3:31 am
RESET_9999 wrote: Wed Jan 27, 2021 9:20 pm no BDMV support via USB
single BDMV inside in AVCHD folder on usb works
DaMacFunkin
#4319 Post by DaMacFunkin » Thu Jan 28, 2021 6:03 am
Identify the correct mpls file, either on the interweb or by opening the disk with makemkv.
Drag that mpls file into tsmuxer, job done.
DaMacFunkin
#4320 Post by DaMacFunkin » Thu Jan 28, 2021 6:07 am
morbius wrote: Wed Jan 27, 2021 9:24 pm thanks for clarifying. And it looks like I'll be stuck with selecting a forced/default sub track manually? So many films have these. In any event, it will be useful for me to have a DV-capable disc player to give me a reference for playback from other sources.
Get the Oppo clone and rip to iso or BDMV.
Subtitles will work as if you was playing the disk.
You can also use external subs with the .forced flag if you want to add subtitles to a title.
