Alright, I understand if it it's same quality on both I'll just buy the best one with best DLNA streaming. It's a bit lame they don't support high bitrate movies though is it limited by a 100mbps connection or wifi? Or any way to fix since most Blu-Ray rips can reach 140Mbps? Also curious what formats in dolby vision it supports like mkv, mp4 etcRESET_9999 wrote: ↑Wed Jan 27, 2021 12:07 pmAll the bluray players have the same DV SDK so they all output the same quality.XTrojan wrote: ↑Wed Jan 27, 2021 8:13 amI have been checking out some BluRay players, specifically the Panasonic UB820, The sony X700, X800M2 and X1100. In most reviews it says the UB820 has the best PQ for Dolby Vision but it has subpar support for playing back ripped BDs. Do the Sonys have as good network streaming support (of Bluray files) like for say Kodi or Plex does (without the dolby vision bugs/issues, full support MEL & FEL and TV-Led playback)?
Yes the Sony support tv-led, FEL, MEL... No DV color issues. All of this has been answered in the past few days. you guys should read the thread a bit instead of repeating the same questions over and over
Network playback(DLNA, no plex) works too but it's not fast enough for high bitrate movies.
Second question, ripping with MP4 like on this thread, is it a profile that contains MEL+FEL and everything? Was thinking of trying to test this on my LG CX with the WebOS player to try to see the difference (if it works)
