bobby121418
Re: Ultimate UHD Drives Flashing Guide Updated 2021
Post by bobby121418 » Wed Jan 27, 2021 11:35 am
I followed the instruction here to downgrade my BU40N from encrypted firmware 1.04 to 1.03
How To Flash Videos and commands:
New Updated guide for all Drives and firmware including encrypted firmware: https://www.youtube.com/watch?v=jyQV1aPlbow
1. Open cmd as admin
2. Navigate to makemkvs install directory by default on 64 bit systems it is here: cd "C:\Program Files (x86)\MakeMKV"
3. If you have a listed encrypted firmware you must use this command: makemkvcon64.exe f --all-yes -d “ your drive letter here Example: D”: rawflash enc -i “path to your firmware Example: C:\Users\Billy\Downloads\Downgrade-Enabled-Firmware\Auto-Flash\LG-Desktop-NS60-sleep-fix\WH16NS60-1.02-MK.bin”
4. If you have unencrypted firmware use this command: makemkvcon64.exe f --all-yes -d “ your drive letter here Example: D”: rawflash -i “path to your firmware Example: C:\Users\Billy\Downloads\Downgrade-Enabled-Firmware\Auto-Flash\LG-Desktop-NS60-sleep-fix\WH16NS60-1.02-MK.bin”
5. Remove my examples and quotes ”” when you run the commands
https://www.youtube.com/watch?v=Yfpf6HoMMis only for unencrypted firmware
https://www.youtube.com/watch?v=eXgybNfHhcg - Obsolete but can be useful for recovery
The process went successfully, however I as put a 4K disk, the drive attempts several read attempts, but then I get a message that there is no disk.
Any suggestions please?
Bob
Post by Billycar11 » Wed Jan 27, 2021 11:45 am
bobby121418 wrote: Wed Jan 27, 2021 11:35 am
Bob
Did it read 4K discs before the flash the BU40N should.
How is the drive connected?
bobby121418
Post by bobby121418 » Wed Jan 27, 2021 12:07 pm
Billycar11 wrote: Wed Jan 27, 2021 11:45 am
Bob
Thanks for quick response.
I am afraid I did not test prior to flash.
Its a slim drive in a Vantec USB3.0 and connected via USB to laptop.
Post by Billycar11 » Wed Jan 27, 2021 12:32 pm
Use both cables on separate usb circuits
And if still no open it up and make sure the slim sata connection is fully seated
bobby121418
Post by bobby121418 » Wed Jan 27, 2021 1:33 pm
Billycar11 wrote: Wed Jan 27, 2021 12:32 pm Use both cables on separate usb circuits
Just tried that as well as cleaning the disk several times, but still the result is the same. I am assuming the firmware change is not the issue here. Could it be the 4K disk is bad?
Post by Billycar11 » Wed Jan 27, 2021 1:35 pm
bobby121418 wrote: Wed Jan 27, 2021 1:33 pm
Could be try regular Blu-ray and a dvd if possible that has a different laser
No this would not be related to firmware I don't think
bobby121418
Post by bobby121418 » Wed Jan 27, 2021 5:10 pm
Billycar11 wrote: Wed Jan 27, 2021 1:35 pm
Just tried a Blu ray disk and works fine!
Any other suggestions please?
Could it be an issue with the disk or the drive?
bobby121418
Post by bobby121418 » Wed Jan 27, 2021 7:48 pm
bobby121418 wrote: Wed Jan 27, 2021 5:10 pm
Ok, thus is weird, now I tried to open the disk just in Windows with MakeMKV off and now it seems to read the disk. Entering MakeMKV it is also reading the disk although I am seeing some Scsi errors with Medium Error messages.
Post by Billycar11 » Wed Jan 27, 2021 10:33 pm
Post the full log here
bobby121418
Post by bobby121418 » Wed Jan 27, 2021 10:38 pm
Billycar11 wrote: Wed Jan 27, 2021 10:33 pm Post the full log here
How?
Post by Billycar11 » Wed Jan 27, 2021 10:39 pm
bobby121418 wrote: Wed Jan 27, 2021 10:38 pm
How?
Copy paste from the makemkv output is the easiest way
Post by MartyMcNuts » Wed Jan 27, 2021 11:02 pm
Breach wrote: Wed Jan 27, 2021 10:09 am Just registered to get your advice. I've done quite a bit of reading on this forum - impressive work guys! My situation is that I'm moving to Ryzen which precludes watching officially any UHD BD content with PowerDVD (insane situation with that SGX requirement, but that's another story).
For my use case I plan to rip with MakeMKV and also use AnyDVD HD for PowerDVD. I considered WH16NS60 and BU40N, but the first is almost impossible to find in Europe and both are UHD official drives, hence won't work with AnyDVD.
So, I'm buying an LG BH16NS55.
Questions:
1) There actually seem to be BH16NS55 drives under both LG and Hitachi branding (the front panel is different). Does anyone know whether there is a hardware difference...?
2) I will probably get a v1.05 official firmware, so if understand correctly, I'll just need to flash the BH16NS55 v1.05 MK firmware with 'enc' selected in the flasher, correct?
3) Then, I understand I can cross-flash to the latest WH16NS60 MK firmware (without 'enc') to fix the sleep bug, etc.
- Is there any reason NOT to go to the latest latest available WH16NS60 MK firmware (I think 1.03)
- Would WH16NS60 MK flashed BH16NS55 work with AnyDVD [Edit: I understand that's a 'no'... so it's either no AnyDVD and no sleep bug (WH16NS60 MK), or AnyDVD and sleep bug (BH16NS55 MK), right?]
1. Doubt there would be.
2. Probably and yes.
3. Correct and correct, NS60 firmware does not work with AnyDVD. Newer firmware is generally not better.
Breach
Post by Breach » Wed Jan 27, 2021 11:33 pm
MartyMcNuts wrote: Wed Jan 27, 2021 11:02 pm 3. Correct and correct, NS60 firmware does not work with AnyDVD.
Brilliant, thanks! I see now that the "sleep bug" is apparently worked around in the latest beta of AnyDVD, so I'll then stay on NS50 v1.05 MK. Cheers!
jonghotti
Post by jonghotti » Thu Jan 28, 2021 3:46 am
Mr_Orange wrote: Sun Jan 24, 2021 10:25 am What's with the obsession with slim drives? Aren't they less reliable than a full-sized internal SATA drive?
[/quote}
Hold on there Mr. Orange let's stick to the facts here:
1. When compared to the 5.25" (I call them "full" sized apparently the technical term is "half" sized) drives the slim drive is smaller.
2: When compared to the 5.25" drives the slim drive is slower (8.0X big drive, 6.0X slim drive).
3. When installed in the Vantec enclosure of the matching size the slim enclosures USB port is way more fragile than that of the full sized enclosure - and if you force the cable into the slim Vantec it easily snaps off and you are hosed :(
4. Slim drive disc tray is also more fragile than that of the large drives - slim drive tray releases with a button and then must be operated by hand (don't slam the thing closed or yank it open!! On the flip side the trays on the larger drives are electronically controlled with a button - press once to open, press again to close.
5. Lastly, the LG BU40N slim drive is unique in that it's currently the only known drive that will occasionally completely fails to enforce the cardinal rule of optical drives. That rule is "do not destroy the physical media that you've been tasked with manipulating!".
The BU40N is currently the only known drive that has demonstrated it's ability to malfunction and leave the disc scratched to the point of usability! This has now been seen with firmware 1.00 and 1.03 so beware!
(This issue has just been escalated to the manufacturers with the goal of understanding and elimination of this behavior :)
Post by Billycar11 » Thu Jan 28, 2021 4:24 am
jonghotti wrote: Thu Jan 28, 2021 3:46 am
i have gotten way more complaints of discs exploding on the desktop drives even before speed control. lg and asus for some reason think it is a good idea when it has trouble reading a spot it rapidly spins up and down idk why.
