UHD Friendly in linux
Simple question here from a newbie. If you have successfully created a libredrive using windows 10, can the drive be used on a Linux system with no further modification?
Re: UHD Friendly in linux
Yeah, both of mine work just fine on Gentoo.
yes once flashed it then works on anything that can run the latest version of makemkv or the ones that that started supporting UHD
Thanks folks. Made my day!
