UHD Friendly in linux
Burnsy01
Post by Burnsy01 »
Simple question here from a newbie. If you have successfully created a libredrive using windows 10, can the drive be used on a Linux system with no further modification?
beandog
Re: UHD Friendly in linux
Post by beandog »
Yeah, both of mine work just fine on Gentoo.
yes once flashed it then works on anything that can run the latest version of makemkv or the ones that that started supporting UHD
Burnsy01
Post by Burnsy01 »
Thanks folks. Made my day!
