Is my drive UHD Friendly?
jamieukguy1470
#1 Post by jamieukguy1470 » Tue Jan 26, 2021 3:19 pm
Part of my label has come off on my Drive, from searching my drive BH16NS40 seems to be compatible, but I've also read that some version aren't.
Is there any way for me to test?... I have put a UHD disc in and it just spins = no read.... Not sure if I need to flash it first though?
Thanks 👍
Re: Is my drive UHD Friendly?
#2 Post by Woodstock » Tue Jan 26, 2021 4:08 pm
Load a regular bluray. Start MakeMKV. What does MakeMKV display in the Info window, under LibreDrive information?
jamieukguy1470
#3 Post by jamieukguy1470 » Tue Jan 26, 2021 9:02 pm
#4 Post by Woodstock » Tue Jan 26, 2021 10:34 pm
MakeMKV says you're LibreDrive compatible, and LD is running.
But your drive pre-dates UHD, so the hardware doesn't do UHD (need late 2015 at the EARLIEST for UHD capability).
So, your final answer is "No".
jamieukguy1470
#5 Post by jamieukguy1470 » Wed Jan 27, 2021 3:44 pm
Thanks for taking the time to reply :)
