Because I would have to turn off Dolby vision every time I want to watch HDR10/SDR content . otherwise, with DV turned on it would be in fake DV.deadchip12 wrote: ↑Tue Jan 26, 2021 1:18 amSorry I don't really understand this part... Say a movie is hdr10 only, why don't you play the m2ts file using the x700 but a htpc instead?
Anyway, even if there was an auto-match mode for DV/HDR10 on the x700, I would still use my HTPC for HDR10/SDR because it's much more practical. plus nothing can beat madVR when there is up-scaling involved (I have an RTX3070
Also, I will use the Shield for MEL DV movies if they ever fix the red push issue. So eventually on my end, the x700 will only be good for FEL movies
The Sony X700 or X800 or the Oppo.
