I have a few more questions:RESET_9999 wrote: Tue Jan 26, 2021 1:39 amBecause I would have to turn off Dolby vision every time I want to watch HDR10/SDR content . otherwise, with DV turned on it would be in fake DV.deadchip12 wrote: Tue Jan 26, 2021 1:18 am Sorry I don't really understand this part... Say a movie is hdr10 only, why don't you play the m2ts file using the x700 but a htpc instead?
Anyway, even if there was an auto-match mode for DV/HDR10 on the x700, I would still use my HTPC for HDR10/SDR because it's much more practical. plus nothing can beat madVR when there is up-scaling involved (I have an RTX3070).
Also, I will use the Shield for MEL DV movies if they ever fix the red push issue. So eventually on my end, the x700 will only be good for FEL movies
The Sony X700 or X800 or the Oppo.XTrojan wrote: Tue Jan 26, 2021 1:26 am Is there any "bug-free" method of playing back Dolby Vision right now with all it's features (FEL+MEL, whatever you name it) or should I just keep myself to HDR10?
-what is the usb port on the x700? Is it usb 3.0? For high bitrate movies, is there any problem (e.g. stuttering, freezing) playing the dolby vision m2ts file straight from the external hdd connected to the x700? Gemini Man in 4k 60fps dolby vision is an example. That file stutters like hell on my c9, but probably that's because the c9's chip is not powerful enough, not because of the usb speed.
-why do you need the Shield when you have a powerful pc and the x700 that can play everything I wonder?
