Tried switching the drop down for all 3 types.
This is the error I get:
MakeMKV v1.6.3 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/marcus/MakeMKV_log.txt
File 00001.mpls was added as title #0
File 00026.mpls was added as title #1
File 00003.m2ts was added as title #2
File 00004.m2ts was added as title #3
Title #00005.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #4
Title #00007.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00009.m2ts was added as title #5
File 00010.m2ts was added as title #6
File 00011.m2ts was added as title #7
Title #00012.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00014.m2ts was added as title #8
Saving 1 titles into directory /Volumes/SansDigital/New/The_Truman_Show
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12753567744'
DEBUG: Code 0 at Mm#L1?GE`"?D){UR:213137091
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12757039104'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12758151168'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12759330816'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12759595008'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12759920640'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12760774656'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12761296896'
DEBUG: Code 101016576 at &A(f>JE\[s!ChSo7zb:29395839
DEBUG: Code 101016576 at &A(f>JE\[s!ChSo7zb:121261727
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12761296896'
DEBUG: Code 0 at cR3d*r`Hdg`H7>:b#5H:121263958
DEBUG: Code 0 at Ne:3kp,(FyN,CxPLM45?:29394298
DEBUG: Code 0 at %MS|^TQabTLK,a(QZLQe:121261681
DEBUG: Code 0 at Ne:3kp,(FyN,CxPLM45?:29394183
DEBUG: Code 6231102 at Ne:3kp,(FyN,CxPLM45?:29393309
DEBUG: Code 0 at db(U'_iL&izym*Rbn#V*O:29397449
Failed to save title 0 to file /Volumes/SansDigital/New/The_Truman_Show/title00.mkv
0 titles saved, 1 failed
Truman Show
setarip_old
Re: Truman Show
Hi!
That looks like an error from something other than an original Blu-ray disc...
marcusfan
Re: Truman Show
It is the original bluray disc. It almost finishes, but fails toward the end.
marcusfan
Re: Truman Show
Also fails when trying to make a backup of the disc.
Backing up disc into folder "/Volumes/SansDigital/New/backup/THE_TRUMAN_SHOW_AC"
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12761628672'
DEBUG: Code 0 at ~4G;8ON}h'>-e;`bVbyS:213135688
DEBUG: Code 0 at ~4G;8ON}h'>-e;`bVbyS:213140265
Backup failed
Backup failed
setarip_old
Re: Truman Show
I'd try cleaning the disc (again, if you did that before) and, if that doesn't do the trick, return it to the place of purchase in exchange for another one...
marcusfan
Re: Truman Show
Returned and got another disc and it worked. The returned disc was a pretty new disc though and only played once before before.
setarip_old
Re: Truman Show
You're quite welcome ;>}
