Wonder wandering
jtapoling
Wonder wandering
Post by jtapoling »
Getting "The source file '/VIDEO_TS/VTS_21_1.VOB corrupt or invalid at offset" error on the movie Wonder. Seems to be stuck in a loop now.
Re: Wonder wandering
Usually that's due to dirt or scratches on the disk. Try cleaning it with a clean, damp, soft cloth.
monkeyhead
Post by monkeyhead »
It was giving me the same message, but it seems to be working now. Lots of corrupts bits, though. Way more than usual. Brand new DVD, too. Hmmmm...
Also, there are two nearly identical-sized files, 6.4 gb and 6.5 gb. I'm assuming one of them is the Spanish Language version of the film. Any guesses as to which is which?
UPDATE: Failed to copy the 6.5 gb file. Going to try the 6.4. gb file instead. But yeah, lots and lots of corrupt errors. Wondering if I should try a Blu-Ray instead.
powerboy322
Post by powerboy322 »
this one works
Title information
Source title ID: 55
Duration: 1:52:58
Chapters count: 16
Segment count: 1
Segment map: 2-18
File name: title09.mkv
oreotookie
Post by oreotookie »
Thank you so MUCH!
