quietvoid
#4231 Post by quietvoid » Thu Jan 21, 2021 11:59 pm
Eventually you might be able to get on the fly conversion from profile 7 to profile 8.1, at least with Kodi.
Then all files would be compatible with most devices at playback.
I don't believe streaming devices will ever get full support for profile 7 FEL.
I've already patched my Kodi to fix the DoVi/HDR10+ issue with the Firestick, so it's not that hard.
Just takes someone to do the work, basically just porting an RPU parser to C++.
Too bad yusesope hasn't shared their code, otherwise we'd have it already.
#4232 Post by shawnc22 » Fri Jan 22, 2021 12:38 am
Unfortunately true. I don't see any streaming devices putting in the extra work to be able to process FEL simply because no such content exists from streaming services. Besides, even if they wanted to, Dolby may not grant them the necessary licenses for fear of piracy. Best hope may be a smart blu-ray player that can run Plex/Kodi. The xbox series x could've been the ideal device, but sadly it has a pretty gimped bluray player with regards to DV.
What was the issue that needed patching?
quietvoid
#4233 Post by quietvoid » Fri Jan 22, 2021 12:49 am
The Firestick Dolby Vision decoder panics and renders a black screen when it encounters a file that contains both Dolby Vision and HDR10+ metadata.
The source of the --skip-hdr10plus switch :)
I basically implemented the same behavior on the fly before the data gets sent to the decoder.
deadchip12
#4234 Post by deadchip12 » Fri Jan 22, 2021 1:35 am
So oled tvs' internal media player and the oppo 203 are still the best ways to watch these DV remuxes?
JavierAlbadalejo
#4235 Post by JavierAlbadalejo » Fri Jan 22, 2021 1:52 am
But TV internal players aren't the best for playback, they lack chapters, may lack capacity for some audios (LG CX for example lacks DTS support).. lacks PGS support.. is it really worth it?
DaMacFunkin
#4236 Post by DaMacFunkin » Fri Jan 22, 2021 7:52 am
Your right, it probably isn’t worth the hassle, I have gone back to ripping FEL titles as Movie only ISO and watching on the Chinoppo, I upgraded my server with an extra 24tb of the Christmas break so I’ve got space to play with for a while.
Do love the convenience of Kodi / Plex/ HT4 though ☹️
lexyz
#4237 Post by lexyz » Fri Jan 22, 2021 7:57 am
I wonder is possbile to force non-dv video to play as dv via kodi on Shield TV?
It would help to better understand "red push" cause on Shield.
Since p7 and p8 are affected (both in TV-led and Player-led modes) and p5 is not there is only logical conclusion that something wrong with YCbCr processing on Shield's DV decoder. P5 is IPT
To prove it we should play plain HDR10 or SDR video via DV decoder.
But there is not possible for user to force DV output on Shield for non-dv video.
jayf95
#4238 Post by jayf95 » Fri Jan 22, 2021 8:56 am
I'm out of the loop. Kodi can pay DV content now? Is this only for mp4s or mkvs as well?
Also if you or anyone else could answer this: assuming playback of DV content in remuxes improves in the near future, will it make any differences whether the TV supports TV led DV vs player led DV? I'm debating between a sony x950h (player led) and x900h (TV led-what I currently have but considering switching due to better PQ/higher peak brightness in the 950h)
lexyz
#4239 Post by lexyz » Fri Jan 22, 2021 9:06 am
Hold for XJ models:
TV-led
New XR processor
jayf95
#4240 Post by jayf95 » Fri Jan 22, 2021 10:30 am
Hold for XJ models:
TV-led
New XR processor
I can't unfortunately. The return period for my x900h ends in mid February and if I return the TV I wont have one to replace it (I sold my old TV).
#4241 Post by Manixx2020beyound » Fri Jan 22, 2021 10:45 am
I can try forcing LLDV on the shield on hdr10 content it’s possible, did it before.
quietvoid
#4242 Post by quietvoid » Fri Jan 22, 2021 1:39 pm
I don't know about the Shield, but the Firestick only triggers Dolby Vision for the TV when there is proper metadata.
Otherwise, there is an option to have Dolby Vision enabled all the time. I don't think the Shield can do that.
MP4s with official releases, MKVs with custom builds: https://forum.kodi.tv/showthread.php?ti ... pid3003730
deadchip12
#4243 Post by deadchip12 » Sat Jan 23, 2021 3:47 am
So an oled CX owner on avsforum just confirmed with me that the tv's internal media player couldn't play this DV DL test file properly: https://drive.google.com/file/d/1NK71Ck ... XLXEa/view
On my C9 it looked fine and played fine. Seems like LG did remove the ability to play dual layer dolby vision file from the CX (and probably upcoming oled tvs as well). That sucks.
lexyz
#4244 Post by lexyz » Sat Jan 23, 2021 7:23 am
RESET_9999 wrote:
Thu Jan 21, 2021 12:37 am
a lot more obvious with the capture card.. wow:
https://screenshotcomparison.com/comparison/10303
thank's @Manixx2020beyound
Can you please recheck Shield TV on MIF bath fight scene with capture card?
https://screenshotcomparison.com/comparison/6913
Is it me or there is some noticable improvement with 8.2.2 update?
Can't spot red blocking while playing mkv via plex.
DV triggered
Maybe I just missed this very frame.
Meanwhile Dr Sleep still has noticable red push
dapope
#4245 Post by dapope » Sat Jan 23, 2021 7:40 am
As of the recent update CX can play P7 Dual Layer mp4s. But MEL only.
The 07.06 file you linked to is Dual Track, not Dual Layer.
