Help - can't rip anything suddenly!
chrisnewbold
Post by chrisnewbold » Fri Jan 22, 2021 7:27 pm
Hi everyone. After being absolutely fine make MKV is giving me errors ripping Bu-rays to mac - 0 titles saved!
sounds like the drive is running really slowly and it may have started to fail on larger files, but now seems to be everything. Drive issue? Have tried 3 different discs and cleaning them. Unplugging drive, restarting...
Debug code!
DEBUG: Code 2281701379 at Hd7!UIYZuj>f?J9[:29399197
chrisnewbold
Re: Help - can't rip anything suddenly!
Post by chrisnewbold » Fri Jan 22, 2021 10:06 pm
So an update already
Yes it is longer files. I can hear the drive struggling. it seems to have got worse. I think eventually it gives up. The error relates to drive power.It's random. One file that failed once just ripped successfully, but takes lots of attempts.
The drive has always been ok directly plugged into USB, but perhaps a combination of it failing and connection via usb is meaning it is now struggling to maintain data flow for those longer files?
I may need a new drive.. any recommendations for an external mac friendly blu ray drive, perhaps with power and of course not rip locked?
Log
MakeMKV v1.15.4 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/iMac/MakeMKV_log.txt
Optical drive "BD-RE hp BDRW BU20N BW20d" opened in OS access mode.
Using LibreDrive mode (v06.2 id=08300AB0DD2E)
Evaluation version, 3 day(s) out of 30 remaining
File 00028.mpls was added as title #0
File 00029.mpls was added as title #1
File 00030.mpls was added as title #2
Title 00017.mpls is equal to title 00028.mpls and was skipped
Title 00018.mpls is equal to title 00029.mpls and was skipped
File 00021.mpls was added as title #3
Title 00027.mpls is equal to title 00030.mpls and was skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title #00006.m2ts has length of 12 seconds which is less than minimum title length of 20 seconds and was therefore skipped
File 00024.m2ts was added as title #4
Title #00037.m2ts has length of 12 seconds which is less than minimum title length of 20 seconds and was therefore skipped
File 00008.m2ts was added as title #5
Saving 1 titles into directory /Volumes/Media Drive/Video Projects/Doctor Who/Ripped DVDs/Season 10 Disk 6
Title 1 skipped
0 titles saved
Saving 1 titles into directory /Volumes/Media Drive/Video Projects/Doctor Who/Ripped DVDs/S12 disk 6
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00022.m2ts' at offset '5174329344'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk6' at offset '5174329344'
DEBUG: Code 1073741829 at Y-mC`x[kMzOi'pp:A}:29395149
(starts to really struggle a this point!)
Post by Woodstock » Fri Jan 22, 2021 10:36 pm
Speed-sensitive power issue. Too much speed for the available USB power.
Best thing to do is to make sure full USB power is available; If you're not plugged in to the computer itself, always use a separately-powered USB hub.
chrisnewbold
Post by chrisnewbold » Fri Jan 22, 2021 10:50 pm
Tried going via powered usb hub... still a problem. is there a way of slowing the drive down then - or new drive??
chrisnewbold
Post by chrisnewbold » Fri Jan 22, 2021 10:51 pm
But i actually am plugged in directly and and it's USB3... up until a few days ago, same set up was fine.
Post by dcoke22 » Fri Jan 22, 2021 10:57 pm
chrisnewbold wrote: Fri Jan 22, 2021 10:50 pm Tried going via powered usb hub... still a problem. is there a way of slowing the drive down then - or new drive??
MakeMKV Speed Control:
https://www.makemkv.com/forum/viewtopic ... 19&t=22689
Post by dcoke22 » Fri Jan 22, 2021 11:02 pm
chrisnewbold wrote: Fri Jan 22, 2021 10:06 pm I may need a new drive.. any recommendations for an external mac friendly blu ray drive, perhaps with power and of course not rip locked?
There's a whole sticky thread about drives: https://www.makemkv.com/forum/viewtopic ... 16&t=19634
I have both an LG WH16NS60 and an ASUS BW-16D1HT, both in OWC Mercury Pro cases and connected via USB to my Mac. I bought the ASUS from a seller here on the forum and it was super easy.
jonghotti
Post by jonghotti » Sat Jan 23, 2021 6:03 am
Original Poster sir I suggest two things 1. Uninstall makemkv v1.15.4 completely and forever. Don't be afraid to use something like Appcleaner 2 to really clean up the remnants. Once done restart computer and install MakeMKV 1.15.1 you can grab it here: https://drive.google.com/file/d/1iofovI ... sp=sharing
This is not a permanent change but more of an experiment to see if things start working again. So please report back :)
2.In my signature if my contact info. I would love to discuss getting you a new drive! Thank you!
chrisnewbold
Post by chrisnewbold » Sat Jan 23, 2021 7:55 am
jonghotti, do you have the MACOS link for 1.15.1?
jonghotti
Post by jonghotti » Sat Jan 23, 2021 8:08 am
chrisnewbold
Post by chrisnewbold » Sat Jan 23, 2021 10:39 am
Thanks I'll try.
Douglasfirs
Post by Douglasfirs » Tue Feb 02, 2021 9:49 am
So yeah,
I'd like to piggy back on this thread and not create a new one.
I have a Buffalo Optical Drive BN12. Has been successful with every single thing I threw at it from the day I bought it. A couple weeks ago it just stopped working. I inserted a disc. it tried to read a disc. made ticking noises before automatically ejecting the disc. I thought the drive went bad.
I'm still under warranty, reached out to Buffalo, they had me run tests. But when I inserted an audio cd, it read it. So they said it wasn't faulty. Then I inserted a Blu-ray. Reads the disc fine with Makemkv. Every single regular SD DVD I insert, it makes that ticking noise and then ejects. Blu-ray's seem to work fine and audio cd's seem to work fine as well. But regular DVDs, nope. Even ones that I ripped in the past, they no longer are read. Just ticks and ejects.
Was the software changed or something? I'm trying to figure out what happened, especially when I had success in ripping DVDs in the past, those same DVDs no longer are read....
