MakeMKV Batch Converter
kofal
Re: MakeMKV Batch Converter
Post by kofal » Tue Feb 14, 2017 4:10 am
Hello to everybody following this thread, I have good (no, great!) news!!!
I have been in contact with/working with the developer of MakeMKVBatch, and he has now brought the site back online!
it can be found here: https://alexgritton.github.io/MakeMKVBatchConverter/
mwijas
Post by mwijas » Sat Feb 18, 2017 3:38 pm
To the developer (agritton) of this tool. I have been using it to convert a rather large media collection to MKV and I have a few feature requests that I believe would benefit anyone using the tool.
1. Allow the in-progress text shown in the Current Conversion window to be saved, or at minimum copied and pasted. When I convert a large number of files, I need to review this information and take appropriate action for those which had an issue. Ideally, this could be written to a log file, and have the log file updated at the completion of each source file (i.e,. if there were 100 source files, the log file would be written to/updated 100 times). The reason this approach is necessary is because if the entire program crashes during a conversion process, all of the information in the Current Conversion window is lost (unless written to a logfile throughout the conversion process). For anyone who might be concerned about this (writing to a logfile) adding time to the conversion, you could make it so that it can be turned on or off with a checkbox on the Advanced tab.
2. Allow for the records in the Conversion Queue to be saved to a file, or at least copied to the clipboard. When I have completed a conversion of many records, I need to go back and review the activity results (#1 above) against each record in the Queue. Ideally, this could be written to a file on demand (before or after the conversion is complete). Again, it needs to be written (or copied) in the event the entire program crashes during a conversion process, all of the information in the Conversion Queue is lost.
3. In the Current Conversion window, please add a reference to the filename (from the Queue) at the start of each conversion. As it stands now, currently the only way to reconcile the results between the Current Conversion window and the Conversion Queue is to count records from the start, which is extremely cumbersome.
4. Add the ability to ‘Select All’ in the Conversion Queue. Consider the following - if I am processing several hundred records (500 for example), and those source files were all added in one step because they were all contained in a single directory, and with 50 records remaining to be converted, the entire application crashes (or hangs) – I now have to go back and add all 500, and then deselect 450 one-by-one to get to the 50 remaining that still need to be converted. This is extremely cumbersome and it would be much better to ‘Select All’ and manually deselect the 50 I need.
5. Add the ability to Stop the conversion.
Once again, thanks for the great tool and I hope you are able to implement these improvements!
Heinrich
Post by Heinrich » Fri May 12, 2017 1:11 pm
I'm not sure I'm using this particularly effectively.
it's splitting my iso's up into all mkv files but I have no idea for instance which mkv is which episode. So for some shows that don't display their title (like Arrow) I have to fire up the iso and the mkv's and figure out which mkv is which episode. This is pretty slow. Throw in the deleted scenes and such ... plus I'm getting sometimes more than one mkv of the same episode. Am I missing something? is there an easier, less time consuming process?
Devious
Post by Devious » Fri May 12, 2017 1:20 pm
Just wanted to say thank you for this program.
BobRPC
Post by BobRPC » Mon May 22, 2017 12:26 pm
Awesome find, your program did a great job of batch converting my ISOs to MKV, thank you!
couple notes for new users of this great tool:
1. I noticed that the original file name must have lower case .iso extension, if named with uppercase .ISO the program will not acknowledge the file exist
2. If I select 'Same as source" for destination the conversion will fail. Choosing a different folder for output fixed the problem for me.
Bmirak
Post by Bmirak » Fri Dec 06, 2019 2:03 pm
This utility is excellent. It could potentially save me hours converting my video_ts and BDMV library to MKV.
I have only two questions:
1. Is it possible to change the output file name to remove the all caps and underscores? For example, I’d like “The Greatest Showman” to read like that - not THE_GREATEST_SHOWMAN.
2. This might be a MakeMKV issue, but for some reason when I convert video_ts files, the resulting MKVs all play with the English subtitles enabled. I can then turn them off in the movie playback, but is there any way to avoid the subs being activated by default?
lrp2000a
Post by lrp2000a » Tue Nov 10, 2020 7:03 pm
It appears some people are able to use this but I've been stuck. I have a folder on a share drive with quite a few ISO's. The converter identifies all of the ISO's and I can manually select them (it would be nice to have the ability to select all). For testing purposes I'm just asking that the converted files stay in the same folder although ultimately I'd prefer to move them to a different folder and remove the ISO or move the converted ISO to a completed folder.
When I click "Start" a second window of the same utility opens showing current conversion showing the first ISO as "In Progress" but never moves past that. Interestingly it selects all folders and not just the ones I select so perhaps I don't understand what the select box is for.
bobross
Post by bobross » Fri Nov 13, 2020 10:42 pm
Is the page down or is that something on my end? Can someone please re-host?
mpking
Post by mpking » Mon Nov 16, 2020 5:49 pm
Github states no such page. :-(
Post by Woodstock » Mon Nov 16, 2020 10:12 pm
littlebo81
Post by littlebo81 » Fri Jan 22, 2021 3:46 am
Woodstock wrote: Mon Nov 16, 2020 10:12 pm Github search comes up with: https://github.com/alexgritton/MakeMKVBatchConverter
looks like file there is some old version, says 8yrs old. or its just one revision and it was never updated or modified ?
hope someone still has that fresh MSI from that disappeared Github repository.
Post by Woodstock » Fri Jan 22, 2021 1:53 pm
The original author hasn't been on this forum for almost 4 years, so it's hard to guess what the status of the repo is/was.
Chetwood
Post by Chetwood » Sat Jan 23, 2021 8:49 am
MMh, it would appear, it's still online cause I have an 'MakeMKV Batch Converter.appref-ms' (426 Bytes) that is a link to
https://alexgritton.github.io/MakeMKVBatchConverter/deploy/MakeMKV%20Batch%20Converter.application#MakeMKV Batch Converter.application, Culture=neutral, PublicKeyToken=4089dc9231c37d42, processorArchitecture=msil
and when I click on it, version 3.0.0.12 opens despite an .application file being nowhere to be found on my system.
watchy
Post by watchy » Wed Mar 10, 2021 7:24 pm
littlebo81 wrote: Fri Jan 22, 2021 3:46 am
https://drive.google.com/file/d/1OOogy8 ... sp=sharing
Zales
Post by Zales » Sat Mar 13, 2021 9:24 pm
Thank you so much @ Watchy for posting the updated version. I have an older version and could not figure out why it did not behave like I thought.
