These are the error messages I'm encountering:
- Automatic HK downloading is disabled or failed
- The volume key is unknown for this disc - video can't be decrypted
- Failed to open disc
I hope someone can help me with this. Thank you!
Yes, for any discs you previously opened, those keys will already have been downloaded to your system. It's probably best to go to the main thread on this topic that I linked above. It sounds as if some others are also experiencing the issue, so it's likely server downtime, and you'll just have to wait for it to be resolved.joheinable wrote: Fri Jan 22, 2021 9:33 am I'm having the same errors recently. Checked DNS and Firewall as mentioned in the postet thread(s).
I can open Discs I opened before though, no idea if this is hinting to anything. Any further ideas?
