Trouble Ripping UHD discs
filmripper21
#1 Post by filmripper21 » Fri Jan 22, 2021 3:29 am
Hello everyone, a newbie here needing some help ripping UHD discs using my new drive I bought from Alex a week ago. I can rip regular bluray discs perfectly, without encountering any problem. The problem lies with me trying to rip my 4K discs -- backing up the whole folder works alright but I don't want to do that because I do not have unlimited disk space.
These are the error messages I'm encountering:
  • Automatic HK downloading is disabled or failed
  • The volume key is unknown for this disc - video can't be decrypted
  • Failed to open disc
I hope someone can help me with this. Thank you!
preserve
Re: Trouble Ripping UHD discs
#2 Post by preserve » Fri Jan 22, 2021 3:38 am
These messages indicate that MakeMKV tried to download the latest keys, but failed. You may have a firewall or DNS issue. If you have an antivirus program running, it may be blocking the download.
viewtopic.php?f=1&t=17848
Using: ASUS BW-16D1HT 3.00
joheinable
#3 Post by joheinable » Fri Jan 22, 2021 9:33 am
I'm having the same errors recently. Checked DNS and Firewall as mentioned in the postet thread(s).
I can open Discs I opened before though, no idea if this is hinting to anything. Any further ideas?
preserve
#4 Post by preserve » Fri Jan 22, 2021 12:17 pm
Yes, for any discs you previously opened, those keys will already have been downloaded to your system. It's probably best to go to the main thread on this topic that I linked above. It sounds as if some others are also experiencing the issue, so it's likely server downtime, and you'll just have to wait for it to be resolved.
joheinable
#5 Post by joheinable » Fri Jan 22, 2021 12:51 pm
Thanks, suspected as much.
SyrimSloane
#6 Post by SyrimSloane » Sun Jan 24, 2021 2:20 pm
Use a VPN.
