Post by Manixx2020beyound » Wed Jan 20, 2021 11:48 pm
lexyz wrote:
Wed Jan 20, 2021 6:48 pm
RESET_9999 wrote:
Wed Jan 20, 2021 3:10 pm
yep, just sell that TV and get an LG lol.
Even Dolby recommends to the colorist the LG C7 or newer for previewing.
Not an option. I like Sony's motion handling and HDR10 8)
New 2021 Bravias will support TV-led DV
P7 fel hdr10 vs p7 fel dv
Post by RESET_9999 » Thu Jan 21, 2021 12:37 am
you got me curious. I checked that scene on my x700 and I find FEL DV sightly cleaner than HDR10 and P8 DV.
thank's @lexyz for the samples
HDR10 vs P7 FEL: https://screenshotcomparison.com/comparison/10301
a lot more obvious with the capture card.. wow:
https://screenshotcomparison.com/comparison/10303
thank's @Manixx2020beyound
JavierAlbadalejo
Post by JavierAlbadalejo » Thu Jan 21, 2021 1:24 am
I'm not regretting my CX OLED, it's fantastic, as a display I love it. It's so good.
I'm not gonna end up worrying if I ever put a DV movie through Plex and it looks bad for some reason. There's always the HDR playback...
quietvoid
Post by quietvoid » Thu Jan 21, 2021 1:39 am
but unless @Manixx2020beyound gave me the wrong capture sample, it looks that the p8 single layer file also fixes the artifacts.. WTF??? now I'm confused...
https://screenshotcomparison.com/comparison/10304
Possibly better processing, dithering by the Dolby Vision engine regardless of EL.
Post by RESET_9999 » Thu Jan 21, 2021 1:52 am
we found out what happened, he misnamed the capture of the p4 dual layer sample from lexy to p8. sorry
here's the real P8 SL vs HDR10 source: https://screenshotcomparison.com/comparison/10306
so the artifacts are there, appears different because of the brightness difference probably caused by the dynamic metadata.
So yes the FEL can make a HUGE difference.
quietvoid
Post by quietvoid » Thu Jan 21, 2021 2:00 am
But does it work on the Shield after all?
Post by RESET_9999 » Thu Jan 21, 2021 2:02 am
nop, i confirmed yesterday that the shield is ignoring the EL. Well Nvidia staff also said it a while ago as Shawn said.
see:
https://www.makemkv.com/forum/viewtopic ... 00#p104113
lexyz
Post by lexyz » Thu Jan 21, 2021 6:49 am
Total Recall is extreme example.
EL is about 40% of bitrate in this scene. Very rare case
Demo-level stuff 8)
Jokes aside it's a defect and it's a mistery how such grade passed quality control.
Seems like all film grain remains in FEL :)
Do you understand now why StudioCanal disks called "blocky-vision" on blu-ray.com? :lol:
Post by RESET_9999 » Thu Jan 21, 2021 2:36 pm
yep, truly incredible bad encoding.
Post by Manixx2020beyound » Thu Jan 21, 2021 3:30 pm
Just wondering how much more off an impact is the fel in rgb dv 8bit doblyvision.
I think the super red color change has something to do with the bt2020 vs p3 encoding.
Tomas
Post by Tomas » Thu Jan 21, 2021 6:14 pm
Greetings to you all. I would like to ask what it looks like now playing with Dolby Vision movies in mkv in Zidoo z9x. Does FEL and MEL play it? I have a Shield for 2019 and I'm considering buying a Zidoo z9x if it pays off. SHIELD plays just fine FEL and MEL. I read that the Zidoo z9x has better colors. Thank you for your help.
JavierAlbadalejo
Post by JavierAlbadalejo » Thu Jan 21, 2021 6:42 pm
So, you guys saying that DV on MKV on Plex/Shield is faulty.. will it ever be fixed in a possible update no matter how long it takes, or are we doomed?
Post by shawnc22 » Thu Jan 21, 2021 8:04 pm
As far as I know, FEL titles will never be played to their full capacity on the Shield, because it's simply a hardware limitation. MEL titles on the other hand and the color issues that exist with them, nvidia is still working on it, but since DV rips from disks are not really officially supported, only time will tell if and when that gets sorted out.
JavierAlbadalejo
Post by JavierAlbadalejo » Thu Jan 21, 2021 8:11 pm
I do have a Sony UHD BD player that has Dolby Vision, particularly the 700 something, but with the new TV I legit do not have the space for it, so I can not hook it up in any form.
But even if it was possible, I do prefer the much easier, faster, click and play part of streaming instead of putting disc (remember in the Sony Blu rays, you have to manually switch on and off DV everytime you play a DV disc!)..
Ride_UL
Post by Ride_UL » Thu Jan 21, 2021 10:27 pm
My TV can play MP4, TS, M2TS DolbyVision files via Default player and MKV DolbyVision remuxes via Modified Kodi (32-bit version)\
Any idea which format is best for accurate color and quality?
