Hi everyone,
any idea how the 4 main features of the movie differ? They are all about the same size and length.
FPL_MainFeature_RegAC_UR
FPL_MainFeature_RegAC_R
FPL_MainFeature_RegB_UR
FPL_MainFeature_RegB_R
Any idea? I am ripping all four of them for now.
Total Recall (2012 Remake) - 4 Main Features
Re: Total Recall (2012 Remake) - 4 Main Features
It looks like you have a release of the Extended Director's Cut. I don't have quite the same disc, but similar in terms of the playlist naming. (I have the Mastered in 4K release and the Extended Director's Cut release from Canada.)
I'm going to go with "UnRated" vs Rated - you should see that the "UnRated" Extended DC is approximately 12 minutes longer - and then you also have different localized playlists - one covering Region A&C, and one for Region B, presumably with different language audio/subtitle options in the playlists.
Using: ASUS BW-16D1HT 3.00
