Re: SDFtool Flasher
Hi, this is the image from the top of the drive
Re: SDFtool Flasher
Strange should have worked this is why I recommend the one step flash process not 2 steps like you did less chance of something going wrong should have flashed directly to WH16NS60 1.02mk just return it and get another.Beans wrote: Thu Jan 21, 2021 9:41 am Hi, this is the image from the top of the drive
Looks beat up for a new drive anyway on the sticker
Re: SDFtool Flasher
Is it worth me trying the Recover option in SDFtool?
If I consider returning it, is there a way that I can make the drive look like I've not tried to flash the firmware?
i.e. Can I flash with the original 1.05 firmware and if so, where can I get the correct file?
I wish I had tested a non UHD drive before attempting to flash it, as there's always the possibility that the drive wasn't working to begin with.
Re: SDFtool Flasher
I've now tried updating with the official firmware update from the LG website, but I get this message.
Should I use SDFtool to flash with one of the old files, such as
mk-firmware-pack-20200720\MK\old\HL-DT-ST-BD-RE_WH14NS40-NS50-1.03-NM00600-211711211658.bin ??
Re: SDFtool Flasher
Don't even worry about it they don't checkBeans wrote: Thu Jan 21, 2021 4:51 pm I've now tried updating with the official firmware update from the LG website, but I get this message.
Re: SDFtool Flasher
@beans if amazon UK return policy is similar to US/CA, then it’s no issue to return. I just returned the ASUS and got instead the LG WH16NS40. Details of firmware used are in this earlier post.
The LG seems quieter and more reliable than the other ASUS, at least in my experience.
- IMG_6639.jpg (298.13 KiB) Viewed 26156 times
Re: SDFtool Flasher
Help! I'm trying to rescue an early model WH16NS40 that got stuck on official firmware 1.05, but I can't find the appropriate firmware file to begin the process, and FirmwareExtractor fails on the WH16NS40_1.05.exe installer from LG.
Re: SDFtool Flasher
i just did this with another guy just follow this:autofire wrote: Sun Jan 24, 2021 11:41 pm Help! I'm trying to rescue an early model WH16NS40 that got stuck on official firmware 1.05, but I can't find the appropriate firmware file to begin the process, and FirmwareExtractor fails on the WH16NS40_1.05.exe installer from LG.
https://www.makemkv.com/forum/viewtopic ... 15#p104021
Re: SDFtool Flasher
No can do - my mobo isn't compatible with IDE, so dosflash is not an option...Billycar11 wrote: Mon Jan 25, 2021 2:21 ami just did this with another guy just follow this:autofire wrote: Sun Jan 24, 2021 11:41 pm Help! I'm trying to rescue an early model WH16NS40 that got stuck on official firmware 1.05, but I can't find the appropriate firmware file to begin the process, and FirmwareExtractor fails on the WH16NS40_1.05.exe installer from LG.
Re: SDFtool Flasher
Well sorry man if sdf tool is not working and you can't do dos flash your done for.autofire wrote: Mon Jan 25, 2021 4:59 pm
Unless you want to send it to one of us drive flashers but it's not worth it just buy a new drive
Re: SDFtool Flasher
Hi Marty, I just registered to say thank you.MartyMcNuts wrote: Tue Aug 18, 2020 1:39 am Hi everyone,
I have created a windows GUI for the MakeMKV sdftool command line flasher. The appearance (and use) is similar to the modifed ASUS flasher, which should make it a bit easier for those that are unsure about using the command line. The latest is version 1.2.0.
I have side loaded my BH16NS55 1.05 to BH16NS50 and then upgraded to DE_WH16NS60 1.00. Work like a charm.
Thanks again. Now I am going to het MakeMKV.
Re: SDFtool Flasher
Awesome! and you're welcome!!chang69 wrote: Mon Jan 25, 2021 10:43 pmHi Marty, I just registered to say thank you.MartyMcNuts wrote: Tue Aug 18, 2020 1:39 am Hi everyone,
Enjoy!
necrogeddon
Re: BH16NS40 1.05 recovered
Hey bud I got the exact same problem as you had doing the same thing, I update innocently to official 1.05 from 1.03. It's been 4 days trying EVERYTHING including voodoo and black magic to no avail. Last chance is the DotFlash32 which i didnt check yet cos I need to install somewhere a x86 copy of win 10. My question is, which bin did you use to go back to 1.03? Many thanksWlassek wrote: Thu Jan 14, 2021 9:16 am Thanks for all. My problems (no disc detected in my BH16NS40 with latest 1.05 FW) seems to be solved by DosFlash32 which was included in USB recovery ISO (boot from flash to Win etc.). Many thanks. Now I´m on 1.03 FW and all seems to be ok. Thanks again and have a nice day![]()
EncryptedEggs
Re: SDFtool Flasher
Ok trying now to figure out which firmware I should choose for my WH16NS40. I have the mk-firmware-pack-20200720 downloaded.
EncryptedEggs
Re: SDFtool Flasher
Ok I saw viewtopic.php?f=16&t=19634&start=540#p103656 and used HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936. Works like a charm now! Thanks all.
