Riplock Removal Matshita USB BD-MLT UJ260
StephenM
Post by StephenM »
Does anyone know if it is possible to defeat Riplock on this drive?
If so, could someone point me in the correct direction
Apologies if this is not the correct part of the forum.
Re: Riplock Removal Matshita USB BD-MLT UJ260
When you load MakeMKV, does it display information about LibreDrive in the right-hand window? You may have to load a disk in the drive for it to display.
If not, then there's nothing MakeMKV can do to manipulate the drive's speed. If it does display information, it will have a section on drive speed.
StephenM
Post by StephenM »
Woodstock wrote: Wed Jan 20, 2021 3:43 pm When you load MakeMKV, does it display information about LibreDrive in the right-hand window? You may have to load a disk in the drive for it to display.
Sadly it looks likely my drive is not LibreDrive compatible.
Oh, well.
