"Convert" is maybe the wrong word. I just used it since its used to describe what yusesope's tool (https://www.makemkv.com/forum/viewtopic ... 970#p96282) is used for.agneva wrote: ↑Tue Jan 19, 2021 11:58 amboth pics are from the original Dual Track, Dual Layer with FEL !AndreasT wrote: ↑Tue Jan 19, 2021 5:58 am
But you didn't convert the FEL to MEL as asked right? The pics on the right is from a Dual Track Dual Layer file with FEL?
In addition to the original question comparing UHD playback with a FEL to MEL conversion, it would be interesting to compare a FEL to MEL conversion to when only the BL is played without HDR at all.
I mean, if only the BL is played, with no HDR at all, is the picture really as dark as when playing a DV dual track dual layer with FEL?
left side on the Bluray Player, right side from the CX interal Player.
I don´t know what you mean with "BL is played without HDR" - sorry.
If you play BL HDR10 the picture is correct.
If you play Dolby Vision Single Layer (only RPU) the picture is as the right side, both on the Bluray player and on the TV.
You can´t convert FEL to MEL.
So what does that tool really do then?
When I use it the resulting mp4 plays on my LG CX what appears to be fine, e.g. as your left picture, with DV and what seems to be ok colors. I tried both starting with a UHD backup and use this tool to "mux and convert to MEL" creating a "converted" single track that i then put into a mp4 file. I also tried to use a mkv from makemkv as the source, and use that tool to "demux and convert to MEL", and then mux the two resulting files as separate video tracks in an mp4 file (using mp4muxer v1.0.0). In both cases the files plays with DV and what appears ok colors.
