Re: Ultimate UHD Drives Flashing Guide Updated 2021
smush wrote: Wed Jan 20, 2021 12:37 pm
jonghotti wrote: Wed Jan 20, 2021 1:48 am Come on man! Just say no to Amazon give the sellers on this board your business before making the little bald man richer!
It’s all about community here! Sure we argue a Lil bit in public but so does every family :-)
Haha I appreciate the offer but I would like to learn how to do this. Between the LG WH14NS40 and ASUS 16D1HT, is one of them better? is one easier to use/flash?
Same in every way hardware everything it's just a rebrand
smush
Post by smush »
Billycar11 wrote: Wed Jan 20, 2021 1:25 pm
OllieBaba
Post by OllieBaba »
Was trying out DVD Fab and they say they have a tool to downgrade firmware and make a drive usable. Have an Asus 16D1HT. Has anyone ever used this tool and if so did it work? Thanks
jonghotti
Post by jonghotti »
OllieBaba wrote: Thu Jan 21, 2021 12:45 am Was trying out DVD Fab and they say they have a tool to downgrade firmware and make a drive usable. Have an Asus 16D1HT. Has anyone ever used this tool and if so did it work? Thanks
Stop what you’re doing do not spend 109 dollars on that tool I will help you with this for free.
Email or text me info is in my signature. Don’t PM me here I don’t check them much.
The
jonghotti
Post by jonghotti »
Yes ASUS is both easier to flash (can use a different easier flasher for the ASUS) and is a much higher quality (faster, longer lifespan) device to begin with.
garmin123
Post by garmin123 »
Cerus wrote: Tue Jan 12, 2021 7:42 pm So I took the easier way and used the sdftool_flasher and the mk-firmware-pack-20200720.
Ran the tool and flashed to HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440 from the "HL-DT-ST" folder with the enc option checked (after forgetting to click it the first time)
Then flashed to HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936 from the "old" folder without enc checked.
No errors and drive seems to be working fine. Is 1.02 still the best firmware to be on or should I flash to the DE 1.00 or MK 1.01? I only use MakeMKV for ripping.
I just got the same drive with 1.05, and perhaps you can offer some help.
1) I'm assuming I can just attach this to a SATA port on my MB and do this in Windows 10? Or must I boot with a 32-bit OS (I believe there's a 32-bit version of windows 7 for this purpose
2) Why wouldn't you go straight to the 1.02? Why is it easier to to use the (presumably) hacked version of 1.05 and then downgrade?
3) I assume you first grabbed the original 1.05 from the drive to flash back in case something failed?
garmin123 wrote: Fri Jan 22, 2021 1:31 am
1. Yes, can be flashed straight from windows 10 using SDFtool Flasher.
2. You can flash WH16NS60 1.02-MK directly if you want. It's just less confusing for some (especially those that don't want to use WH16NS60 1.02-MK) to flash the MK version of 1.05 first due to firmware encryption.This is because only a few (of the many) firmwares are able to be flashed directly from an encrypted firmware.
3. It is not possible to extract the stock 1.05 firmware.
smush
Post by smush »
Got the ASUS drive and have fitted it in my PC I've also downloaded MakeMKV. Just wondering what my next steps should be didn't want to go ahead without checking in here so as not to brick the drive.
I put a UHD disk in and MakeMKV says "No disk inserted"
Device Information in MakeMKV states revision is 3.10 firmware date is 2119-01-04 :shock:
smush wrote: Sat Jan 23, 2021 4:49 pm
You can email me for a self flash kit but the info is here
garmin123
Post by garmin123 »
MartyMcNuts wrote: Sat Jan 23, 2021 1:48 am
Thanks for the reply.
1) When you say the SDFTool, is it the one in the MakeMKV program directory? Is it the SDFTool or the SDFTool64?
2) Must the SATA channel be set to IDE in the BIOS?
garmin123 wrote: Sat Jan 23, 2021 10:15 pm
1. No it's linked on first page sdftool
2.no leave it as default
smush
Post by smush »
Billycar11 wrote: Sat Jan 23, 2021 9:20 pm
So I download the latest version of the MK firmware pack and use the ASUS BW-16D1HT .bin file for flashing using this guide https://www.youtube.com/watch?v=jyQV1aPlbow ? I'm assuming the firmware I have 3.10 is encrypted and so need to use "enc" in the flashing command?
smush wrote: Sat Jan 23, 2021 11:50 pm
No it's not ecrypted where does anyone say that read the guide that firmware is not listed under the encrypted list
smush
Post by smush »
Billycar11 wrote: Sun Jan 24, 2021 12:27 am
Ok I see now was just having difficulty with how some of it was worded.
The part that says
"LG 1.04+ / BU40N 1.03 / Asus 3.10+ and similar
The newer OEM firmwares cannot be flashed easily due to the additional downgrade checks implemented by the drive/firmware manufacturer. If your drive has one of these firmwares, and there is no MK version of the same firmware/drive model or higher number, you will have to sidegrade to Asus 3.10MK "
Since my firmware is 3.10 and there's a 3.10 MK I'm good to go - download the MK firmware pack and flash using the ASUS BW-16D1HT .bin file? I can use the SDFtool instead of command line right? (not using the "enc" option)
atrus821
Post by atrus821 »
Hi all - I wanted ask some of the resident experts here what combo of drives you use as your go-to for blu-ray mkv rips. I have been using an LG BP50NB40, which is a usb powered drive. I've recently added the ASUS BW-16D1HT with an OWC Mercury Pro 5.25" Optical Drive External Enclosure. I'm also considering adding an LG WH16NS60 to the mix as well. I am only ripping my Blu Rays and no UHDs at this point (so flashing has not been relevant for me yet).
So, what drives to you all regularly use? Are any more tolerant/effective? How to you mount these - external enclosures or internal in a PC? There are many posts here about long lists of compatible drives, but I'd love to know which specific models the most frequent posters use.
