Watchmen, HBO correct playlist
thercrh
#1 Post by thercrh » Sat Dec 12, 2020 6:05 pm
Has anyone teased out the correct playlists for the three disc release of HBO Watchmen?
The entire series is only 9 episodes and I'm getting 5 on each disc so there has to be some obfuscating going on.
Thanks in advance.
thercrh
Re: Watchmen, HBO correct playlist
#2 Post by thercrh » Sat Dec 12, 2020 6:11 pm
I just had a second look and noted that multiple playlists use the same segment list even though they rip to different sizes.
I'm going to assume that I can use either of the matching playlists.
Mmuiwdcwnc
#3 Post by Mmuiwdcwnc » Mon Jan 18, 2021 8:06 pm
How did this end up?
preserve
#4 Post by preserve » Tue Jan 19, 2021 1:09 am
Wouldn’t expect obfuscation. Likely different versions for some reason, such as extended cuts, different audio done as separate playlists (commentary, or a separate playlist for Japanese), etc.
If there are different segments you should look at which segments are different and then check those segments specifically to see what the difference is.
You can also do a “dump” of the disc structure if you want someone who doesn’t have this series to take a closer look at it: viewtopic.php?f=10&t=23959
Using: ASUS BW-16D1HT 3.00
stupidman
#5 Post by stupidman » Wed Jan 20, 2021 7:02 am
The only difference in the 801/802/803 sequence and the 851/852/853 sequence looks like the subtitles/languages available - otherwise the video content is identical as far I can tell.
