King of Queens Blu-ray S5D2E20 "The source file is corrupt or invalid at offset"
ShatteredGlass
Post by ShatteredGlass » Tue Jan 19, 2021 10:51 am
I'm trying to backup my King of Queens Blu-ray box set and I've run across an error that I've never seen before. I was able to backup the entire box set (206 episodes) except ONE EPISODE! Season 5 Disc 2 Episode 20 (Driving Reign). While backing up the title, MakeMKV gets just under halfway and then starts throwing "source file is corrupt" errors. I've tried four different blu-ray drives and two different models, and all fail at the same point. So I thought, ok, it's probably the disc then. But the episode plays just fine when I play it in the Sony blu-ray player connected to my TV as well as on an Xbox One.
I posted the output window log below. I've ripped hundreds of discs and I've never come across this issue before. Is there anyway to get MakeMKV to ignore this issue and continue to process the rest of the file?
MakeMKV v1.15.4 win(x64-release) started
Using LibreDrive mode (v06.2 id=D79E993B8FCA)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE BP50NB40 1.03' at offset '24935858176'
File 00001.mpls was added as title #0
File 00002.mpls was added as title #1
File 00003.mpls was added as title #2
File 00004.mpls was added as title #3
File 00005.mpls was added as title #4
File 00006.mpls was added as title #5
File 00008.mpls was added as title #6
File 00010.mpls was added as title #7
File 00011.mpls was added as title #8
File 00012.mpls was added as title #9
File 00013.mpls was added as title #10
File 00014.mpls was added as title #11
File 00015.mpls was added as title #12
Title #00009.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory M:/MakeMKV/S5D2
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422465024, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422465024-1422471168, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422471168, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422471168-1422477312, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422477312, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422477312-1422483456, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422483456, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422483456-1422489600, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422489600, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422489600-1422495744, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422495744, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422495744-1422501888, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422501888, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422501888-1422508032, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422508032, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422508032-1422514176, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422514176, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422514176-1422520320, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1422520320, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458044928, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458044928-1458051072, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458051072, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458051072-1458057216, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458057216, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458057216-1458063360, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458063360, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458063360-1458069504, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458069504, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458069504-1458075648, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458075648, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458075648-1458081792, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458081792, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458081792-1458087936, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458087936, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458087936-1458094080, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458094080, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458094080-1458100224, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458100224, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458100224-1458106368, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458106368, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458106368-1458112512, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458112512, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458112512-1458118656, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458118656, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458118656-1458124800, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458124800, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458124800-1458130944, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458130944, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458130944-1458137088, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458137088, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458137088-1458143232, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458143232, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458143232-1458149376, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458149376, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458149376-1458155520, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458155520, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458155520-1458161664, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458161664, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458161664-1458167808, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458167808, attempting to work around
Hash check failed for file 00010.m2ts at offset 1458235392, file is corrupt.
Hash check failed for file 00010.m2ts at offset 1458432000, file is corrupt.
Hash check failed for file 00010.m2ts at offset 1458628608, file is corrupt.
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1458561024-1458573312, attempting to work around
Hash check failed for file 00010.m2ts at offset 1459415040, file is corrupt.
Too many hash check errors in file 00010.m2ts.
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1459752960, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1461749760, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1461749760-1461755904, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1462401024, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1462474752-1462487040, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1462505472, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1462505472-1462511616, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1462511616, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1467389952-1467396096, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1467420672, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1467420672-1467426816, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1467426816, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1467691008-1467697152, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1467697152, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1468993536, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1471653888, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1471678464, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1472692224, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1472956416, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1474510848, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1475352576-1475358720, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1475358720-1475377152, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1475395584, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1475395584-1475401728, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1475401728-1475407872, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1476814848, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1476814848-1476820992, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1476820992, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1477208064, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1477208064-1477214208, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1477214208, attempting to work around
The source file '/BDMV/STREAM/00010.m2ts' is corrupt or invalid at offset 1477281792, attempting to work around
Failed to save title 6 to file M:/MakeMKV/S5D2/title_t06.mkv
Encountered 126 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Re: King of Queens Blu-ray S5D2E20 "The source file is corrupt or invalid at offset"
Post by Woodstock » Tue Jan 19, 2021 1:24 pm
The drive cannot read the disk, most likely because it is not clean. And by clean, I mean, "Clean enough for a laser to see all the microscopic holes sharply". "Shiny enough to see myself in" is not a good enough standard.
At the top of this forum is a "sticky" message about common errors and how to deal with them.
ShatteredGlass
Post by ShatteredGlass » Tue Jan 19, 2021 9:00 pm
You must have missed the part where I wrote... I've tried four different blu-ray drives and two different models, and all fail at the same point.
Specifically, I've tried the same disc in three different LG BP50NB40 drives, and I also tried it in my LG BH16NS40. They all fail at the same point. There are 13 episodes on the disc total, I can backup 12 outa 13 episodes from the disc. I'm only having the issue with ONE EPISODE.
Yes I read the sticky, all it says regarding my specific issue is to "replace the disc", which in this situation I feel it won't resolve the issue since the specific episode plays just fine on my Xbox One and Sony Blu-ray player. I watched the entire episode from start to finish, it plays all the way thru without a single glitch. So if those players can read the disc then why is MakeMKV having issues backing it up?
I thought about just returning the box set and exchanging it for another, but I read THIS THREAD where someone had pretty much the exact same issue I'm having, and they replaced the disc with another one and still had the exact same issue. So I'm concerned that replacing the disc isn't going to resolve the issue.
I also backed up the entire disc using WinISO and tried processing the ISO thru MakeMKV, but once again it fails at the same point. I even tried cranking up the "Retry Count" to 99, but to no avail.
Is there any way to force MakeMKV to ignore these errors and process the file anyways? What about any MakeMKV alternatives that I can try to backup this single episode? I've never needed any other tool since MakeMKV has never failed me until now. Is there anything else I can try?
Post by Woodstock » Tue Jan 19, 2021 9:28 pm
And that points at the disk itself.
You can try removing audio or subtitle tracks to see if the error is isolated enough to allow it to rip.
ShatteredGlass
Post by ShatteredGlass » Mon Jun 12, 2023 1:59 am
The issue was the disc. I ended up getting another box set and was able to read that episode from the new disc just fine. Just wanted to post an update on this issue just in case anyone else comes across this in the future. Thanks Woodstock.
