deadchip12
Post by deadchip12 » Mon Jan 18, 2021 10:57 am
agneva wrote: Mon Jan 18, 2021 6:51 am Your Mandalorian is a pirated, reencoded copy :roll: you can tell the x265 encoder what ever you want, maybe L8.5:
Hmm how worse is the reencoded compared to the original I wonder? Disney + is not available in my country so I can't compare.
agneva
Post by agneva » Mon Jan 18, 2021 12:02 pm
this is the EL of Ryan:
BL:
You can demux it and playback with MPC-HC :)
I don´t know Mandalorian.
Post by RESET_9999 » Mon Jan 18, 2021 12:11 pm
deadchip12 wrote: Mon Jan 18, 2021 10:57 am
it's not re-encoded.. it's a true untouched WEB-DL ...
many folks see pirated stuff and automatically assume it's captured / re-encoded.
Dolby Vision cannot be recorded with a capture card. The only way of getting DV rip out of streaming services is by downloading/bypassing the DRM which pirate groups have been able to do for many months now.
agneva
Post by agneva » Mon Jan 18, 2021 12:30 pm
that's not the point here, but it doesn't matter.
Resolution : [3840×2160]
Video Bitrate : [15,3 MB/s]
FPS: : [23,976]
Audio Language : [German (DTS-HD MA 5.1/EAC3 5.1) / English (EAC3 5.1)]
Subtitle Lang. : [German (Complete/Complete SDH) / English (Complete SDH)]
Encoding : [StaxRip -> HEVC x265 Main10 High@L5.1 CRF16 (UHD Ready)]
Colorgrading : [DaVinci Resolve Studio 16 -> BT2020 HDR10 @1000 Nits]
Source : [Mandalorian.S02E01.Chapter.09.REPACK.2160p.WEB-DL.DDP5.1.HDR.x265-RONIN]
x265 is always reencoded, no professional provider encodes with x265 :!:
Post by RESET_9999 » Mon Jan 18, 2021 2:14 pm
agneva wrote: Mon Jan 18, 2021 12:30 pm that's not the point here, but it doesn't matter.
of course, studios encode the file, that's not the point. I was just telling you that WEB-DL means untouched from the Ðisney servers.
agneva wrote: Mon Jan 18, 2021 12:30 pm no professional provider encodes with x265 :!:
that is not true..... there's a couple of uhd-bd that shows that they use x265. mostly the german bluray disc release
also happen all the time with streaming service.. Your own iTunes 1080p DRM download will sometimes show the x264 encoder/ settings. Studios can do whatever they want.
Rollerball uhd bluray:
Video
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 5 min
Bit rate : 59.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.298
Stream size : 52.0 GiB (84%)
Writing library : x265 2.3+18-88fd9082764c:[Windows][GCC 5.3.1][64 bit] 10bit
Encoding settings : cpuid=1050111 / frame-threads=8 / numa-pools=20,20 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=1 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / bframes=4 / b-adapt=2 / no-b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=1 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=0.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=60000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=70000 / vbv-bufsize=60000 / vbv-init=0.9 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13200,34500)B(7500,3000)R(34000,16000)WP(15635,16500)L(20000000,2) / max-cll=10000,400 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / no-hdr-opt / refine-level=5
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.264000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.330000
Mastering display luminance : min: 0.0002 cd/m2, max: 2000 cd/m2
Maximum Content Light Level : 10000 cd/m2
Maximum Frame-Average Light Level : 400 cd/m2
Disc Title:     Rollerball.1975
Disc Size:      77,789,728,995 bytes
Protection:     AACS2
Extras:         Ultra HD
BDInfo:         0.7.5.8
PLAYLIST REPORT:
Length:                 2:05:44.703 (h:m:s.ms)
Total Bitrate:          75.12 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       59212 kbps          2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 2000nits / HDR10 / BT.2020
AUDIO:
Codec                           Language        Bitrate         Description
LPCM Audio                      German          2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
LPCM Audio                      English         2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
DTS-HD Master Audio             German          2347 kbps       5.1 / 48 kHz / 2347 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             English         2333 kbps       5.1 / 48 kHz / 2333 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
* Dolby Digital Audio           English         192 kbps        2.0 / 48 kHz / 192 kbps
FPS: : [23,976]
Also, that file info you posted is clearly re-encoded from the true MZABi WEB-DL which is 22mb/s and doesn't show x265 settings.
of course anyone can call his encode WEB-DL , that why you must stick to the reputable release group, who the hell is ronin lol and that file is not even in DV....
real legit DV web-dl mediainfo of S02 ep01 :
Video
Format profile                           : Main 10@L5.2@Main
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Duration                                 : 51 min 51 s
Bit rate                                 : 22.0 Mb/s
Maximum bit rate                         : 47.3 Mb/s
Chroma subsampling                       : 4:2:0 (Type 0)
Bits/(Pixel*Frame)                       : 0.111
Stream size                              : 7.97 GiB (96%)
Encoded date                             : UTC 2020-11-02 16:16:57
Tagged date                              : UTC 2020-11-02 20:25:13
Color range                              : Full
magnetoeric
Post by magnetoeric » Mon Jan 18, 2021 4:03 pm
Could someone please do a comparison video of FEL from any blu ray player with FEL to MEL converted file played through the internal player of CX (or through native plex app)? Or if it's already done, would be grateful if they link it. Thanks in advance :)
HEMAN
Post by HEMAN » Mon Jan 18, 2021 5:29 pm
I am using the OP method to convert ISO to MP4 that trigger DV. However, its taking too long average is 1 hour complete. Any faster method ? Thank You
agneva
Post by agneva » Mon Jan 18, 2021 6:38 pm
magnetoeric wrote: Mon Jan 18, 2021 4:03 pm Could someone please do a comparison video of FEL from any blu ray player with FEL to MEL converted file played through the internal player of CX (or through native plex app)? Or if it's already done, would be grateful if they link it. Thanks in advance :)
my camera cannot capture the full dynamics of the OLED display, so I fixed it to get a comparable result by photo:
the brightness-pumping can not be seen on a picture :lol:
Wanderlust3K
Post by Wanderlust3K » Mon Jan 18, 2021 9:58 pm
DaMacFunkin wrote: Mon Jan 18, 2021 7:52 am The CX can do TV led Dolby Vision so it has 2 decoders, so no discussion.
What is more likely is the second decoder is crippled in firmware for media file playback.
Have you tried built in Plex app from NAS?
Yep, LG internal player/Plex.
Firmware crippled makes sense, sucks, but makes sense.
Above pictures taken by @Agneva ilustrates the issue pretty well.
AndreasT
Post by AndreasT » Tue Jan 19, 2021 5:58 am
agneva wrote: Mon Jan 18, 2021 6:38 pm
But you didn't convert the FEL to MEL as asked right? The pics on the right is from a Dual Track Dual Layer file with FEL?
In addition to the original question comparing UHD playback with a FEL to MEL conversion, it would be interesting to compare a FEL to MEL conversion to when only the BL is played without HDR at all.
I mean, if only the BL is played, with no HDR at all, is the picture really as dark as when playing a DV dual track dual layer with FEL?
DaMacFunkin
Post by DaMacFunkin » Tue Jan 19, 2021 7:49 am
Wanderlust3K wrote: Mon Jan 18, 2021 9:58 pm
Glad I gave a C9 then, CX in many ways sounds like a backward step.
agneva
Post by agneva » Tue Jan 19, 2021 11:58 am
AndreasT wrote: Tue Jan 19, 2021 5:58 am
both pics are from the original Dual Track, Dual Layer with FEL !
left side on the Bluray Player, right side from the CX interal Player.
I don´t know what you mean with "BL is played without HDR" - sorry.
If you play BL HDR10 the picture is correct.
If you play Dolby Vision Single Layer (only RPU) the picture is as the right side, both on the Bluray player and on the TV.
You can´t convert FEL to MEL.
AndreasT
Post by AndreasT » Tue Jan 19, 2021 1:12 pm
agneva wrote: Tue Jan 19, 2021 11:58 am
"Convert" is maybe the wrong word. I just used it since its used to describe what yusesope's tool (https://www.makemkv.com/forum/viewtopic ... 970#p96282) is used for.
So what does that tool really do then?
When I use it the resulting mp4 plays on my LG CX what appears to be fine, e.g. as your left picture, with DV and what seems to be ok colors. I tried both starting with a UHD backup and use this tool to "mux and convert to MEL" creating a "converted" single track that i then put into a mp4 file. I also tried to use a mkv from makemkv as the source, and use that tool to "demux and convert to MEL", and then mux the two resulting files as separate video tracks in an mp4 file (using mp4muxer v1.0.0). In both cases the files plays with DV and what appears ok colors.
Wanderlust3K
Post by Wanderlust3K » Tue Jan 19, 2021 1:23 pm
I tested the files on my CX.
HDR10 looks fine.
Both DL & SL look WRONG, supper dark --> EL is not decoded on the DL, not present on the SL.
Wanderlust3K
Post by Wanderlust3K » Tue Jan 19, 2021 1:26 pm
AndreasT wrote: Tue Jan 19, 2021 1:12 pm
Keep the RPU data = Dynamic HDR ??
EL is lost, it doesnt matter on MEL tittles since theres only RPU there but MATTERS on FEL tittles, keeping RPU alone is not enough for FEL tittles.
