BucklesMcGee
Post by BucklesMcGee »
So I was in the process of ripping my entire library. So earlier in the day it ripped a BD successfully. Then I had been ripping DVD's then I tried to rip another BD and it just showed it as no disk. This actually happened before I changed the firmware on the drive. I was just running the firmware out of the box. I do not own any UHD disk's so I was not worried about updating the firmware right away.
For context at the time it was connected to a Ubuntu setup. Since then I had moved (physically) to my windows computer and it has the same issue on there. So it has been powered off fully and back on. Oddly, windows showed it as a BD-Drive soft of, in the file explorer that is what the drive was called. Yet still putting in a BD disk it just said there was nothing there. Windows still probably did not read it as a BD drive just was labeled as such.
Since I just purchased it from Amazon. I think I am just going to do a return on it for faulty hardware.
didoin
Post by didoin »
Hi, i have a BH16NS40 (1st gen, SVC Code NS40)
I had version 1.02 but accidentally updated it with the 1.05 (SVC Code NS50).
There is some chance to downgrade.
The player no longer reads any discs.
AlexS
Post by AlexS »
Hello
Stupidly I upgraded my WH14NS40 to 1.05. Then I bought my first ever 4K Blu Ray disc.
I've tried using BH14NS40_N1.00-A4_patched.exe on ROMs:
DE_flash_HL-DT-ST_BD-RE_WH14NS40_1.02_NS50.bin
DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
...and get checksum errors.
Any ideas on what exactly I need to do?
Many thanks..
OS device name: J:
Product: BD-RE WH14NS40
Revision: 1.05
Serial number:
Harware support: Yes
Firmware support: No
Firmware version: 1.05
st4evr
Post by st4evr »
AlexS wrote:
Mon Jan 18, 2021 9:04 pm
Hello
Have you read and tried the method discussed here yet:
https://www.makemkv.com/forum/viewtopic ... 16&t=22896
And we can’t stress enough to carefully read and pay attention to the instructions and/or warnings noted within.
AlexS
Post by AlexS »
Hello
st4evr wrote:
Mon Jan 18, 2021 9:17 pm
Thanks - no I didn't, I started elsewhere so I've begun again from your link....
I've backedup/dumped my existing 1.05 firmware with SDFTool Flasher.
I'm assuming I flash my desktop BluRay H14NS40 with SDFTool Flasher to:
HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444
And then afterwards to DE_ASUS_BW-16D1HT_1.01
Thanks for this...
AlexS
Post by AlexS »
Hello
AlexS wrote:
Mon Jan 18, 2021 9:41 pm
Thanks for this...
OK I managed to do it, I've moved from the original firmware WH14NS40 1.05 to DE_ASUS_BW-16D1HT_1.01 (see specs). The main gotcha was knowing when to tick the encrpted tickbox. Not sure if I have the best firmware for the player or not, but I've just managed to rip Terminator 2 (4K) with DVDFab.
(I did try DE_ASUS_BW-16D1HT_1.01.bin but this didn't work very well with DVD Fab)
If anybody has a WH14NS40, please let me know what you did (and why ideally)... appreciated..
trav06
Post by trav06 »
I bought the LG BP50NB40 and according to the sticker on the bottom the ROM version is 1.03. Hoping someone more knowledgeable than me can confirm these steps so I don't brick it.
1. Flash HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin using ASUS_ODD_FW_Changer
2. Flash HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin using ASUS_ODD_FW_Changer
3. Done?
Thanks in advance for any advice!
trav06 wrote:
Sun Mar 21, 2021 11:22 pm
3. Done?
Step 1 is ok, but you can't use the ASUS flasher as your drive has encrypted firmware. Use the "SDFtool Flasher" with "enc?" checked.
Step 2 should be: Flash BP60NB10 1.01-MK from the MK/old folder using SDFtool Flasher with "enc?" unchecked. Don't use BP60NB10 1.02 as it's crap.
Done!
turok_t
Post by turok_t »
Hello, I'm extremely new at did and I've been reading a lot of the posts in this thread. I'm simply looking for a 4k blu ray drive to rip my 4k movies to my PC and was thinking to get the ASUS BW-16D1HT. Do I simply flash it to MK 3.10? or will I need to use the SDFtool if the existing firmware on the drive is encrypted? I just finished reading all 56 pages of this thread! Sorry for the newb question, I just want to make sure I do this right so I don't brick my new drive! Thanks so much!
CrispyHanako
Post by CrispyHanako »
I'm not sure if I'm just a total idiot (very well could be the case) or something's up, I've gone down rabbit holes trying this that and the other but no matter what tool I use it just gives me an error.
https://youtu.be/GfZghWBGwQ4
Any help would be greatly appreciated.
trav06
Post by trav06 »
MartyMcNuts wrote:
Mon Mar 22, 2021 3:29 am
3. Done?
Done!
Thank you thank you thank you! Haven't gone through the steps yet, but this will save me a lot of trouble.
turok_t wrote:
Thu Mar 25, 2021 5:16 am
The ASUS doesn't have encrypted firmware, so yes simply flash 3.10-MK.
trav06 wrote:
Thu Mar 25, 2021 10:01 pm
3. Done?
Done!
No problem. Also, I mentioned using 1.01-MK in step 2, which is ok, however, I just wanted to say that BP60NB10 1.00-MK is also good and is what I personally use.
CrispyHanako wrote:
Thu Mar 25, 2021 9:45 pm
Read the guide and use sdf tool or command line with enc or email me for an automated flasher all linked below
CrispyHanako
Billycar11 wrote:
Thu Mar 25, 2021 10:10 pm
Jeez now I really do feel like a moron, commandline worked first time.
Thanks!!!
