DaMacFunkin
Post by DaMacFunkin » Mon Jan 18, 2021 7:52 am
Wanderlust3K wrote: Sun Jan 17, 2021 10:24 pm
agneva wrote: Sun Jan 17, 2021 2:37 pm Of course there is an issue.
If you see the white sky is pumping / picture is to dark, the (F)EL is not decoded !
in my opinion the CX can only decode the Metadata (RPU) of DV, not the second HEVC stream.
maybe the older LG TV can do, I don´t know... to find out, I uploaded the samples for you.
THIS !
MEL files look ok
FEL files look ultra dark.
I had a C7 before the CX and FEL files looked fine on the C7.
Manixx2020beyound wrote: Sun Jan 17, 2021 6:18 pm 5ED00217-56EF-4440-B746-9591A31684D2.jpeg
CX plays fel fine in usb mp4 dl dv.
Firmware#
Tlc 6 series plays dv fel as well usb.
CX did not play DV (DTDL) mp4 prior to lastest firmware.
They do play NOW but as @Agneva pointed out, FEL files on CX look bad, too dark, as if EL was ignored alltogether.
That would explain the lack of support at launch.
Who knows maybe, the CX only has 1 decoder instead of the 2 required, would not surprise me, manufacturers undercut sucessfull product lines for profit all the time.
Have seen this happen a lot, a product gets fame for its quality and then next versions are cutdown for profit with inferior materials or features.
Maybe LG thougth no one would notice since streaming is MEL and that would really suck, i dont see much difference beetween DV MEL vs plain HDR + dynamic tonemaping or HDR10+, DV was about FEL.
The CX can do TV led Dolby Vision so it has 2 decoders, so no discussion.
What is more likely is the second decoder is crippled in firmware for media file playback.
Have you tried built in Plex app from NAS?
agneva
Post by agneva » Mon Jan 18, 2021 8:38 am
DaMacFunkin wrote: Mon Jan 18, 2021 7:52 am The CX can do TV led Dolby Vision so it has 2 decoders, so no discussion.
You confuse metadata decoder with 2. full-fledged HEVC decoder :!: (which restores the original from FEL with 12bit)
For Netflix Dolby Vision is only DV Profil 5 / 8 necessary, without 2. HEVC stream / FEL:
DV layers Matrix explained.jpg (89.39 KiB) Viewed 29511 times
Post by shawnc22 » Mon Jan 18, 2021 9:07 am
Being able to do TV-led DV has nothing to do with whether it has 2 HEVC decoders or not. If that's the case, then every DV capable TV that's not a Sony should be able to play DL FEL mp4s. The decoding step (1 HEVC or 2 HEVC decoders needed to reconstruct the original picture) occurs prior to the tone mapping step (TV-led or player-led).
deadchip12
Post by deadchip12 » Mon Jan 18, 2021 10:57 am
agneva wrote: Mon Jan 18, 2021 6:51 am Your Mandalorian is a pirated, reencoded copy :roll: you can tell the x265 encoder what ever you want, maybe L8.5:
Hmm how worse is the reencoded compared to the original I wonder? Disney + is not available in my country so I can't compare.
agneva
Post by agneva » Mon Jan 18, 2021 12:02 pm
this is the EL of Ryan:
Ryan DV DL 07.06.track_2.hevc_snapshot_00.06.735.jpg (310.03 KiB) Viewed 30801 times
BL:
Ryan DV DL 07.06.track_1.hevc_snapshot_00.06.795.jpg (372 KiB) Viewed 30801 times
You can demux it and playback with MPC-HC :)
I don´t know Mandalorian.
Post by RESET_9999 » Mon Jan 18, 2021 12:11 pm
deadchip12 wrote: Mon Jan 18, 2021 10:57 am
it's not re-encoded.. it's a true untouched WEB-DL ...
many folks see pirated stuff and automatically assume it's captured / re-encoded.
Dolby Vision cannot be recorded with a capture card. The only way of getting DV rip out of streaming services is by downloading/bypassing the DRM which pirate groups have been able to do for many months now.
agneva
Post by agneva » Mon Jan 18, 2021 12:30 pm
that's not the point here, but it doesn't matter.
Resolution : [3840×2160]
Video Bitrate : [15,3 MB/s]
FPS: : [23,976]
Audio Language : [German (DTS-HD MA 5.1/EAC3 5.1) / English (EAC3 5.1)]
Subtitle Lang. : [German (Complete/Complete SDH) / English (Complete SDH)]
Encoding : [StaxRip -> HEVC x265 Main10 High@L5.1 CRF16 (UHD Ready)]
Colorgrading : [DaVinci Resolve Studio 16 -> BT2020 HDR10 @1000 Nits]
Source : [Mandalorian.S02E01.Chapter.09.REPACK.2160p.WEB-DL.DDP5.1.HDR.x265-RONIN]
x265 is always reencoded, no professional provider encodes with x265 :!:
Post by RESET_9999 » Mon Jan 18, 2021 2:14 pm
agneva wrote: Mon Jan 18, 2021 12:30 pm that's not the point here, but it doesn't matter.
of course, studios encode the file, that's not the point. I was just telling you that WEB-DL means untouched from the Ðisney servers.
agneva wrote: Mon Jan 18, 2021 12:30 pm no professional provider encodes with x265 :!:
that is not true..... there's a couple of uhd-bd that shows that they use x265. mostly the german bluray disc release
also happen all the time with streaming service.. Your own iTunes 1080p DRM download will sometimes show the x264 encoder/ settings. Studios can do whatever they want.
Rollerball uhd bluray:
Video
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 5 min
Bit rate : 59.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.298
Stream size : 52.0 GiB (84%)
Writing library : x265 2.3+18-88fd9082764c:[Windows][GCC 5.3.1][64 bit] 10bit
Encoding settings : cpuid=1050111 / frame-threads=8 / numa-pools=20,20 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=1 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / bframes=4 / b-adapt=2 / no-b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=1 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=0.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=60000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=70000 / vbv-bufsize=60000 / vbv-init=0.9 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13200,34500)B(7500,3000)R(34000,16000)WP(15635,16500)L(20000000,2) / max-cll=10000,400 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / no-hdr-opt / refine-level=5
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.264000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.330000
Mastering display luminance : min: 0.0002 cd/m2, max: 2000 cd/m2
Maximum Content Light Level : 10000 cd/m2
Maximum Frame-Average Light Level : 400 cd/m2
Disc Title:     Rollerball.1975
Disc Size:      77,789,728,995 bytes
Protection:     AACS2
Extras:         Ultra HD
BDInfo:         0.7.5.8
PLAYLIST REPORT:
Length:                 2:05:44.703 (h:m:s.ms)
Total Bitrate:          75.12 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       59212 kbps          2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 2000nits / HDR10 / BT.2020
AUDIO:
Codec                           Language        Bitrate         Description
LPCM Audio                      German          2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
LPCM Audio                      English         2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
DTS-HD Master Audio             German          2347 kbps       5.1 / 48 kHz / 2347 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             English         2333 kbps       5.1 / 48 kHz / 2333 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
* Dolby Digital Audio           English         192 kbps        2.0 / 48 kHz / 192 kbps
FPS: : [23,976]
Also, that file info you posted is clearly re-encoded from the true MZABi WEB-DL which is 22mb/s and doesn't show x265 settings.
of course anyone can call his encode WEB-DL , that why you must stick to the reputable release group, who the hell is ronin lol and that file is not even in DV....
real legit DV web-dl mediainfo of S02 ep01 :
Video
Format profile                           : Main 10@L5.2@Main
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Duration                                 : 51 min 51 s
Bit rate                                 : 22.0 Mb/s
Maximum bit rate                         : 47.3 Mb/s
Chroma subsampling                       : 4:2:0 (Type 0)
Bits/(Pixel*Frame)                       : 0.111
Stream size                              : 7.97 GiB (96%)
Encoded date                             : UTC 2020-11-02 16:16:57
Tagged date                              : UTC 2020-11-02 20:25:13
Color range                              : Full
magnetoeric
Post by magnetoeric » Mon Jan 18, 2021 4:03 pm
Could someone please do a comparison video of FEL from any blu ray player with FEL to MEL converted file played through the internal player of CX (or through native plex app)? Or if it's already done, would be grateful if they link it. Thanks in advance :)
HEMAN
Post by HEMAN » Mon Jan 18, 2021 5:29 pm
I am using the OP method to convert ISO to MP4 that trigger DV. However, its taking too long average is 1 hour complete. Any faster method ? Thank You
agneva
Post by agneva » Mon Jan 18, 2021 6:38 pm
magnetoeric wrote: Mon Jan 18, 2021 4:03 pm Could someone please do a comparison video of FEL from any blu ray player with FEL to MEL converted file played through the internal player of CX (or through native plex app)? Or if it's already done, would be grateful if they link it. Thanks in advance :)
my camera cannot capture the full dynamics of the OLED display, so I fixed it to get a comparable result by photo:
the brightness-pumping can not be seen on a picture :lol:
Wanderlust3K
Post by Wanderlust3K » Mon Jan 18, 2021 9:58 pm
Yep, LG internal player/Plex.
Firmware crippled makes sense, sucks, but makes sense.
Above pictures taken by @Agneva ilustrates the issue pretty well.
AndreasT
Post by AndreasT » Tue Jan 19, 2021 5:58 am
agneva wrote: Mon Jan 18, 2021 6:38 pm
But you didn't convert the FEL to MEL as asked right? The pics on the right is from a Dual Track Dual Layer file with FEL?
In addition to the original question comparing UHD playback with a FEL to MEL conversion, it would be interesting to compare a FEL to MEL conversion to when only the BL is played without HDR at all.
I mean, if only the BL is played, with no HDR at all, is the picture really as dark as when playing a DV dual track dual layer with FEL?
DaMacFunkin
Post by DaMacFunkin » Tue Jan 19, 2021 7:49 am
Wanderlust3K wrote: Mon Jan 18, 2021 9:58 pm
Glad I gave a C9 then, CX in many ways sounds like a backward step.
agneva
Post by agneva » Tue Jan 19, 2021 11:58 am
AndreasT wrote: Tue Jan 19, 2021 5:58 am
both pics are from the original Dual Track, Dual Layer with FEL !
left side on the Bluray Player, right side from the CX interal Player.
I don´t know what you mean with "BL is played without HDR" - sorry.
If you play BL HDR10 the picture is correct.
If you play Dolby Vision Single Layer (only RPU) the picture is as the right side, both on the Bluray player and on the TV.
You can´t convert FEL to MEL.
