Hi All:
I used the tried and true method of looking at the last actor in the credits and matching the episode from the IMDB cast. I thought I would post the results and save some people some time.
The leftmost number is the episode number.
Here Are Seasons 1 - 3
Mission Impossible TV Series Blu Ray Episode Numbers
- Screen Shot 2021-01-16 at 7.07.43 PM.jpg (260.41 KiB) Viewed 10886 times
- Screen Shot 2021-01-16 at 7.07.53 PM.jpg (246.17 KiB) Viewed 10886 times
- Screen Shot 2021-01-16 at 7.08.03 PM.jpg (277.88 KiB) Viewed 10886 times
Re: Mission Impossible TV Series Blu Ray Episode Numbers
Seasons 4 and 5...
- Screen Shot 2021-01-16 at 7.07.26 PM.jpg (236.61 KiB) Viewed 10885 times
- Screen Shot 2021-01-16 at 7.07.35 PM.jpg (262.38 KiB) Viewed 10885 times
Seasons 6 and 7...
- Screen Shot 2021-01-16 at 7.07.09 PM.jpg (226.15 KiB) Viewed 10885 times
- Screen Shot 2021-01-16 at 7.07.16 PM.jpg (224.02 KiB) Viewed 10885 times
Nice! I've been considering getting this.
However, you might want to consider changing your default naming and number by source ID instead of by title ID. Title ID doesn't match up to anything on the disc, it only reflects the order that MakeMKV loads eligible titles, and the numbering of title IDs can change based on the minimum title length setting, which many users set differently.
Check out this thread for more information.
Using: ASUS BW-16D1HT 3.00
Thanks for the info preserve. I will start to include the information going forward.
For Mission Impossible - My minimum title length was set to 120 seconds.
