[Solved] Unexpected OpenGL error.
dirkmittler
Post by dirkmittler »
Up until yesterday, I was able to get MakeMKV to run. But just today, I get the following error:
/snap/makemkv/232/usr/bin/makemkv: symbol lookup error: /snap/makemkv/232/usr/lib/x86_64-linux-gnu/libGL.so.1: undefined symbol: _glapi_tls_Current
This has got to be some sort of build issue. Can anybody suggest a workaround?
Update:
I was able to resolve this problem, with the following command:
# snap connect makemkv:opengl :opengl
(I had previously disconnected them.) :oops:
Dirk
Re: [Solved] Unexpected OpenGL error.
But, computers are supposed to make our lives EASIER! How could this be?
(glad you found the problem)
