1.6.3 fails to calculate filesize correctly
cbxbiker61
Post by cbxbiker61 »
It won't copy a 21 gig file when there is plenty of space.
The size of output file '/home/kelly/Videos/Wall·E_Disc_1/title00.mkv' may reach
as much as 21697 megabytes while target filesystem has a file size limit of 0
megabytes. Do you still want to continue (title will be skipped)?
df -h .
Filesystem Size Used Avail Use% Mounted on
/dev/sda10 230G 85G 133G 39% /home
grep home /etc/fstab
/dev/sda10 /home ext4 defaults 1 2
Re: 1.6.3 fails to calculate filesize correctly
Post by mike admin »
Thanks, noted.
