Uhd disk and joining the menu files to the movie file
Wire1078
#1 Post by Wire1078 » Fri Jan 15, 2021 6:02 pm
Hi could anyone point me in the right direction please.
I'm new to this group and to mkv. How do you join the mkv files together to make a uhd file thst has menus etc?
Thanks Peter
Re: Uhd disk and joining the menu files to the movie file
#2 Post by Woodstock » Fri Jan 15, 2021 7:54 pm
MKV files do not support menus.
If you want the "disk experience", you should use the backup function, which will re-create the Bluray/UHD file structure, complete with menus.
Wire1078
#3 Post by Wire1078 » Sat Jan 16, 2021 2:28 pm
OK thank you
