Attempting to flash in macOS
Re: Attempting to flash in macOS
Post by dcoke22 » Fri Jan 15, 2021 8:37 pm
bachelorbob wrote: Fri Jan 15, 2021 5:05 pm I have successfully copied (to an ISO image) the film '1917' from a UHD disc…
Out of curiosity, what do you do with the ISO? Do you have a player that plays ISOs?
wookieepuss
Post by wookieepuss » Sat Jan 16, 2021 1:21 am
Just joined up to say thanks for this post. I just flashed successfully a new Asus BW-16D1HT on my Mac in less time than it took to register for this forum.
bachelorbob
Post by bachelorbob » Sat Jan 16, 2021 2:35 am
dcoke22 wrote: Fri Jan 15, 2021 8:37 pm Out of curiosity, what do you do with the ISO? Do you have a player that plays ISOs?
It can be mounted, which then appears as a virtual disc that the Mac OS does not differentiate from a physically mounted disc, or just played as a file. Which method depends on which player application you use. I had been using Blu-ray Player Pro v3.3.20, but I'm trying some others at the moment (including VLC).
Any UHD is a lot of data to dump out of my Thunderbolt (mini-DisplayPort 1.2?), via a mini-DisplayPort to HDMI cable adapter, then 4K HDMI cable to 4K TV. The Thunderbolt port specs up to 4096×2160 (4K) @ 60Hz (10 Gbps), so the only limit *should* be how fast my SSD can read the ISO. Will need a fresh restart and no other applications running to see if I can watch without any hiccups / frame drops.
I guess the short answer is, my MacBook Pro is my player. Just it, a 4K TV, a 5.1 soundbar, and cables.
Post by dcoke22 » Sat Jan 16, 2021 2:56 am
You must have a preference for accessing menus and whatever special features there are on the disc?
Personally, I find getting rid of the menus to be a benefit. I prefer to rip the movie to a .mkv file and leave the rest behind. Some stuff I further compress to 10-bit HEVC or h.264 files. In any case, getting down to just the movie, no menus, no warnings, no trailers, no junk, is my preference.
bachelorbob
Post by bachelorbob » Sat Jan 16, 2021 5:08 am
dcoke22 wrote: Sat Jan 16, 2021 2:56 am You must have a preference for accessing menus and whatever special features there are on the disc?
My goal is an exact copy of the disc, minus the physical disc (and UOPs, so I can skip intros, previews, etc.).
Nshawn
Post by Nshawn » Sat Mar 27, 2021 12:24 pm
Is the sdf.bin part of it necessary? I see in other instructions/strings that the add.bin part isn't in it. I'm a noob so just curious and asking.
Post by dcoke22 » Sat Mar 27, 2021 3:29 pm
Nshawn wrote: Sat Mar 27, 2021 12:24 pm Is the sdf.bin part of it necessary? I see in other instructions/strings that the add.bin part isn't in it. I'm a noob so just curious and asking.
viewtopic.php?p=72110#p72110 You need sdf.bin. What are you looking at that suggests you don't need it?
Nshawn
Post by Nshawn » Sat Mar 27, 2021 7:18 pm
dcoke22 wrote: Sat Mar 27, 2021 3:29 pm
In the how to flash video and command section of this page.
viewtopic.php?f=16&t=19634
Nshawn
Post by Nshawn » Tue Apr 20, 2021 3:24 pm
To make sure I don't brick my drive flashing...So I have a Lg WH16NS40 with firmware revision 1.05 encrypted. So when I flash using makemkv do I flash the WH16NS40 1.05mk using the encrypted method and then flash again using the unencrypted method to put on the recommended WH16NS60 1.02MK OR do I flash the WH16NS60 1.02MK right away using the encrypted method. Thanks in advance.
Post by Billycar11 » Tue Apr 20, 2021 7:50 pm
You flash directly to WH16NS60 1.02mk as the guide says less steps that way
Nshawn
Post by Nshawn » Wed Apr 21, 2021 12:55 am
Billycar11 wrote: Tue Apr 20, 2021 7:50 pm You flash directly to WH16NS60 1.02mk as the guide says less steps that way
Great. Thanks for your quick help!
Nshawn
Post by Nshawn » Wed Apr 21, 2021 1:27 am
I assume from the guide that the WH16NS 1.02MK is the better firmware to end up with. What are the differences? Or is there a better one to end up with?
Nshawn
Post by Nshawn » Thu Apr 22, 2021 12:46 am
Attempting flash my wH16NS40 and getting this error. Here is what I had in terminal. Any suggestions? Thanks in advance
Thes-MBP:MacOS Shawn$ ./makemkvcon f -d /IOBDServices/65E3835A -f ~/Applications/MakeMKV.app/Contents/MacOS/sdf.bin rawflash main,enc -i ~/Downloads/The\ all\ you\ need\ firmware\ pack/LG\ 5.25\ desktop/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Unable to load sdf.bin
Internal error 0xffffffff
Post by Billycar11 » Thu Apr 22, 2021 12:47 am
Nshawn wrote: Thu Apr 22, 2021 12:46 am Attempting flash my wH16NS40 and getting this error. Here is what I had in terminal. Any suggestions? Thanks in advance
what usb adapter are you using?
Nshawn
Post by Nshawn » Thu Apr 22, 2021 12:51 am
Billycar11 wrote: Thu Apr 22, 2021 12:47 am
NST536S3
