Brand New DVD - Failed to save title 0
Brand New DVD, wiped clean, tried in 2 different computers (Mac and PC),
Saving 1 titles into directory /Volumes/Public/
DEBUG: Code 4294967295 at MA1n_4Y&'dr&|ToU33D:29393999
DEBUG: Code 0 at Ne:3kp,(FyN,CxPLM45?:29394183
DEBUG: Code 2192557 at Ne:3kp,(FyN,CxPLM45?:29393309
Failed to save title 0 to file /Volumes/Public/title00.mkv
0 titles saved, 1 failed
Is it a defective DVD, should I try to exchange it where I bought it, or is there a setting I might want to try?
Any help is much appreciated
setarip_old
Re: Brand New DVD - Failed to save title 0
Hi!
What's the title and region number of the DVD?
It's an import from Mexico: OV7 - Primera Fila (2010) , and is coded Region "0" (no restriction), and both my two computers are fixed at Region "1".
My PC even has AnyDVD installed.
setarip_old
Turn OFF and exit AnyDVD when using MakeMKV...
Even though I've rip hundreds of DVD's before with AnyDVD activated, and with no problems at all, I did as you said, no AnyDVD activated or in memory in my PC computer. I got this debug message:
Saving 1 titles into directory R:/Pendientes/Renombrar y Reubicar/OV7_PRIMERA_FILA
DEBUG: Code 4294967295 at %E8bm=(3rcY&tpvv,kY:29393999
DEBUG: Code 0 at |/i|nL L~Z~2yo@.:#ln:29394183
DEBUG: Code 2192557 at |/i|nL L~Z~2yo@.:#ln:29393309
Failed to save title 0 to file R:/Pendientes/Renombrar y Reubicar/OV7_PRIMERA_FILA/title00.mkv
I should add that 3 of the 4 tittles that the DVD has, were perfectly copied, and the one with the full feature was ripped to the hard disk up to the 99%, and afterwards deleted.
Remember I've also tried in MacOS X (with no BootCamp or any virtualizer) getting the same results.
setarip_old
I'm guessing it's a poorly mastered disc so, if that's an available option, I'd try that.Is it a defective DVD, should I try to exchange it where I bought it
Of course "mike admin" may have additional insight to offer...
- Contact:
The error shows a corrupted audio track. There is no workaround.
Setarip_old & Mike admin: I sure do appreciate your help. Everything makes sense.
Keep up the great job you're doing!!!
Thanks again
Thanks again
setarip_old
You're quite welcome ;>}Setarip_old & Mike admin: I sure do appreciate your help.
