Hi could anyone point me in the right direction please.
I'm new to this group and to mkv. How do you join the mkv files together to make a uhd file thst has menus etc?
Thanks Peter
Uhd disk and joining the menu files to the movie file
Wire1078
Re: Uhd disk and joining the menu files to the movie file
MKV files do not support menus.
If you want the "disk experience", you should use the backup function, which will re-create the Bluray/UHD file structure, complete with menus.
Wire1078
