Days of Thunder 4K UHD (USA)
mnyman
#1 Post by mnyman » Fri Jan 15, 2021 3:12 am
Greetings!
I'm unable to rip the Days of Thunder 4K UHD movie. The following messages are displayed. Hopefully, someone can make sense of the issue. I've attached the dump file.
Thank you, in advance!
MakeMKV v1.15.4 win(x64-release) started
Using LibreDrive mode (v06.2 id=7FA2657C7667)
Saved AACS dump file as C:\Users\Mark/.MakeMKV/MKB20_v72_Days_of_Thunder_FC83.tgz
Re: Days of Thunder 4K UHD (USA)
#2 Post by Woodstock » Fri Jan 15, 2021 3:19 am
Attaching the dump file is going to delay things - it needs to be emailed to svq@makemkv.com if you want something done about it.
Also, there are a number of topics already posted here about various versions of Days of Thunder, including US, CA, UK, and AU versions. Do you have internet access enabled in your settings, to download the latest hash key data?
mnyman
#3 Post by mnyman » Sat Jan 16, 2021 3:16 am
Thank you very much! Your suggestion was very helpful.
I enabled internet settings, closed, and reopened makemkv. I was then able to open the disc.
I had looked at the other postings regarding "Days of Thunder". From what I can tell, one person was eventually successful, while the others indicated a lack of success. I imagine that your suggestion to enable internet settings would be helpful to everyone who isn't already aware of the setting.
