No Drive Logic Found - LG & Windows VM
craigk61
#1 Post by craigk61 » Wed Jan 13, 2021 5:19 pm
I am attempting to flash the LG BP60NB10. I have the drive connected to my Mac computer, but have assigned it to a Windows VM running on my mac. The drive is found and operational with the Windows version of MakeMKV.
I am using the following command from PowerShell:
.\makemkvcon64.exe f --all-yes -d D: rawflash enc -i C:\Users\Def\Desktop\HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin
When I attempt to flash it, I get the following error:
No drive tool logic found in SDF.bin
Internal error 0x8d000000
I've been over the instructions/videos several times and it appears that I've got the syntax right, but I'm still having no luck.
As a side note, I have also attempted to use SDFtool Flasher v1.2.0, but when I selected the Drive, select WRITE, select the .bin file, and tick enc, and press START, nothing happens.
Anyone with a thought on what else I might try?
Re: No Drive Logic Found - LG & Windows VM
#2 Post by Billycar11 » Wed Jan 13, 2021 10:58 pm
No vms VM bad
#3 Post by dcoke22 » Wed Jan 13, 2021 11:05 pm
You should be able to flash a drive from MacOS.
https://www.makemkv.com/forum/viewtopic.php?f=4&t=23129
