Which firmware is best for the WH16NS40?
revliedparker
#1 Post by revliedparker » Wed Jan 13, 2021 1:42 am
I bought a WH16NS40 optical drive today and I want to be able to burn my UHD movies. Right now its 1.05 and is able to be flashed (NS50, MT1959). My question is that which firmware do I use. I've read that I should use WH16NS60-1.02-MK. But I've read other things that say to flash to a different firmware first, and then use the WH16NS60 1.02 firmware. I just want a clear answer at this point cause I don't wanna try anything until I get an answer.
Re: Which firmware is best for the WH16NS40?
#2 Post by Woodstock » Wed Jan 13, 2021 2:43 am
At the time of this reply, there are currently one thousand three hundred and five hits for "WH16NS40" on this forum, at least a hundred discuss the "best firmware". And a couple of guides that explain the sequence for flashing, based on your original firmware.
#3 Post by Billycar11 » Wed Jan 13, 2021 2:55 am
revliedparker wrote: Wed Jan 13, 2021 1:42 am I bought a WH16NS40 optical drive today and I want to be able to burn my UHD movies. Right now its 1.05 and is able to be flashed (NS50, MT1959). My question is that which firmware do I use. I've read that I should use WH16NS60-1.02-MK. But I've read other things that say to flash to a different firmware first, and then use the WH16NS60 1.02 firmware. I just want a clear answer at this point cause I don't wanna try anything until I get an answer.
flash directly to WH16NS60 1.02 as the guide says with enc option or box checked the developer pinned it for a reason.
