Stuck with downgrade options for BH16NS40 SVC NS51
sdg73
Post by sdg73 » Tue Jan 12, 2021 1:51 pm
Had I known about the issues with this drive I'd have bought a different one, but I'm stuck and need help. This seems like the right place.
I read about flashing to the MK 1.05 equivalent firmware (mine came with 1.05), which I did successfully with SDFtool flasher. The only thing I didn't do was tick the enc box but it still did it.
However, when I now try to flash to anything, I get "command produced error code 0x8f05c103".
Noob question but what am I doing wrong?
SDF tool flasher is showing HL-DT-ST_BD-RE_BH16NS40_1.05_212005061331_KLZK9FB3016.
It successfully reads and rips a regular blu-ray, but doesn't read UHD. It's clearly not bricked but equally something isn't right.
Thanks in advance for any help here.
Best wishes
Sean
sdg73
Re: Stuck with downgrade options for BH16NS40 SVC NS51
Post by sdg73 » Tue Jan 12, 2021 3:41 pm
ok - so I managed to sort this and am now on the Asus 3.10 crossflash - working perfectly.
The error message appears to be because the drive was open (slaps head).
I did the flash using the CMD line code listed on this site, using makemkvconv64. Flashed successfully the first time and had no problems since.
Phew...
Post by Billycar11 » Tue Jan 12, 2021 3:49 pm
check the enc box and use WH16NS60 1.02 as the guide says
sdg73
Post by sdg73 » Tue Jan 12, 2021 9:04 pm
Thanks Billy - but I got it sorted in the end with the ASUS crossflash via CMD.
Regards
Sean
