Audio "Delay Relative to Video" in MKV with Handbrake - What Causes it? How to Fix It?
mike_mgoblue
Post by mike_mgoblue »
Whenever I rip Blu-ray movies I own to MKV videos using MakeMKV, things are fine.
And when I use Handbrake to compress the ripped MKV files to mp4, things are fine.
However, whenever I compress the original MKV files into other MKV files, the "Properties" and "Media Info" in Players such as MPC-BE and MPC-HC show a new category under the Audio. This new category under the Audio is, "Delay Relative to Video."
Whenever I change a DTS sound format into the AC-3 format in order to compress the sound into either 448kbs or 640kbs, it shows a "Delay Relative to Video" of -5ms.
In VLC, in the Codec and Media Information, I do not see that type of "Delay" category listed.
Whenever I change that same DTS sound format into another audio format such as AAC, it is even longer. With AAC it will show a "Delay Relative to Video" of -18ms.
I've studied this online. There are videos that say, "The problem that is likely causing this is Variable Frame Rates." So they say, "The solution is to select Constant Frame Rate in Handbrake." I have done that all along. I've tried it both ways. I even tried one called "Peak Frame Rate." None of those seem to matter.
When I use Handbrake to make only the video, and then use MKVMerge to add the original audio back into the compressed file, things are fine. But, that still leaves those very large audio files that are not good for everything. AC-3 Dolby Digital is the one that has the most compatibility. So, that is the file I'd like to use for audio.
In Handbrake, even if I select "Auto Passthrough" or "DTS Passthrough" for the original audio, it still produces a form of "Delay Relative to Video." But, rather than being "negative," it is "positive." When I use the "Passthrough" in Handbrake, the compressed MKV file will have a "Delay Relative to Video" of 2ms.
One other thing I tried was very interesting. I used Handbrake to compress the original MKV file into an mp4 file. As expected, there was no form of "Delay Relative to Video" shown in the compressed mp4 file. So, I opened MKVMerge and placed the mp4 file in it. I then saved that mp4 file as an MKV file. The MKV file played fine; however, it now had a "Delay Relative to Video" of -2ms.
The "Delay Relative to Video" of -5ms, -4ms, -3ms, -2ms, and 2ms are things I really cannot even notice. I can't even notice the "Delay Relative to Video" of -18ms and -21ms with the AAC format. But, I'm just wondering "Why" does this occur? And "How" can it be fixed?
