Hobbit Part 3 Extended Failure
mbelanger
Post by mbelanger »
Greetings all,
I was able to rip parts 1 & 2 without issue, but part 3 fails around 9G. I've tried ripping the first two options, but both fail in the same way. makeMKV starts spitting out debug errors. The drive is a new LG BU40N and I've successfully ripped half a dozen other UHDs without issue.
I've attached the log, if it helps.
Thanks,
MB
MakeMKV_log.txt
(40.81 KiB) Downloaded 511 times
mbelanger
Re: Hobbit Part 3 Extended Failure
Post by mbelanger »
Those SCSI errors within the log are concerning, but I was able to rip Underworld UHD with no problems, so I'm back to wondering about that disc. Can a disc cause such errors?
This error from your log:
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00014.m2ts' at offset '10944509952'
means that the drive was unable to correctly read the disc. The standard answer here is to gently clean the disc and try again.
See this thread for more detail: https://www.makemkv.com/forum/viewtopic.php?f=8&t=15055
