[SOLVED] Die_Toten_Hosen_-_Hals_und_Beinbruch
dauhuber
Post by dauhuber »
Have strange problems to make .mkv''s from this Bluray.
Everything seems to work, but the .mkv's have no video, only sound (tested with xine, xbmc and vlc).
I experienced the same behaviour with DVDFAB. Some strange encryption? Any suggestion?
I think Debug log looks okay?
  • Debug log started at Thu Jan 20 13:50:30 2011 , written by MakeMKV v1.6.3 linux(x86-release)
    Using 131328KB for read cache.
    001005:0000 MakeMKV v1.6.3 linux(x86-release) started
    001004:0000 Debug logging enabled, log will be saved as /home/dauhuber/MakeMKV_log.txt
    DISCID=342ED1D76634C76A43D280F0068AE912A2EC6503
    003307:0000 File 00001.mpls was added as title #0
    003307:0000 File 00500.mpls was added as title #1
    003307:0000 File 00501.mpls was added as title #2
    003307:0000 File 00503.mpls was added as title #3
    003307:0000 File 00505.mpls was added as title #4
    003307:0000 File 00554.mpls was added as title #5
    003307:0000 File 00008.mpls was added as title #6
    003309:0000 Title 00009.mpls is equal to title 00001.mpls and was skipped
    003309:0000 Title 00522.mpls is equal to title 00554.mpls and was skipped
    003309:0000 Title 00602.mpls is equal to title 00001.mpls and was skipped
    003025:0000 Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
    003025:0000 Title #00011.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
    005014:0000 Saving 7 titles into directory /share/media/video/Die_Toten_Hosen_-_Hals_und_Beinbruch/
    001003:0020 DEBUG: Code 0 at mmS9Y-kHPL%IVQ'XE ET:213130122
    005005:0080 7 titles saved
    005036:0104 Copy complete. 7 titles saved.
    Application exited at Thu Jan 20 14:44:16 2011
setarip_old
Re: Die_Toten_Hosen_-_Hals_und_Beinbruch
Post by setarip_old »
Hi!
Is your source material an original commercial Blu-ray disc, or something else?
dauhuber
Post by dauhuber »
Hi setarip_old
It's the original commercial Bluray which works perfect when I play
with Cyberlink Power DVD or on my SONY BDP-S470.
setarip_old
Try maing a full disc backup first. If the full disc backup or its individual .M2TS files plays properly, use the backup as your source for converting to .MKV...
Post by mike admin »
Looks like player or codec problem - the log looks perfectly fine.
dauhuber
[SOLVED]?Die_Toten_Hosen_-_Hals_und_Beinbruch
Post by dauhuber »
mike admin wrote:Looks like player or codec problem - the log looks perfectly fine.
Finally I got the solution.
Bought a WDTV Player and it plays the .mkv perfect. Somehow strange that it didn't work on my Linux Box
with VLC and XBMC.
However: It was not a problem of makemkv.
