Cant make my new BU40N to rip
Jeppe
Post by Jeppe »
I bought this LG BU40N Slim Drive + Vantec Enclosure from one of the recommended sellers in the forum. It should be plug and play ready.
However I get this error report when I try to backup an UHD disc as you can see in the attachment.
I also get an error when trying to backup a normal bluray disc.
Any thoughts on this will be highly appreciated.
Re: Cant make my new BU40N to rip
Jeppe wrote: Sat Jan 09, 2021 8:06 am I bought this LG BU40N Slim Drive + Vantec Enclosure from one of the recommended sellers in the forum. It should be plug and play ready.
your second picture does not show it but im 99% sure up in top of the log it says hardware timeout on logical unit
drive needs more power use both plugs and or a high powered usb Hub like this: https://smile.amazon.com/gp/product/B00 ... UTF8&psc=1
jonghotti
Post by jonghotti »
Billycar11 wrote: Sat Jan 09, 2021 8:25 am
That's what that message means? How on Earth would a user know that?
jonghotti wrote: Sat Jan 09, 2021 9:03 am
not always but for usb drives thats what it normal means in my experience.
because when drive does not have enough power it reboots and makemkv says its taking to long to respond.
it then boots back up and mkvmkv think LD is still loaded in the ram but its not because of reboot
and you get a bunch of illegal key exchange errors because of it.
Jeppe
Post by Jeppe »
Thank you very much Billy. It worked with both usbs plugged in.
jammer
Post by jammer »
Software can only do so much. As far as I know there is nothing in the USB spec that allows software to know how much power a device can draw from it's power source. All it can now is a device vanished from the USB chain.
jonghotti
Post by jonghotti »
Out of curiosity, what spec would list those log messages?
spl147
Post by spl147 »
Just want to point out to the OP, your drive is NOT Libre Patched!
spl147 wrote: Sat Mar 20, 2021 2:02 pm Just want to point out to the OP, your drive is NOT Libre Patched!
No it is stop talking about something you don't know about
You can see they say it works once they plugged in both cables
spl147
Post by spl147 »
Excuse me? Look at the first pic it clearly states unpatched.
Post by d00zah »
spl147 wrote: Sat Mar 20, 2021 6:55 pm Excuse me? Look at the first pic it clearly states unpatched.
It also clearly states "Status: Enabled" w/ the accompanying 4 - "Yes"s. No need to patch.
spl147
Post by spl147 »
If you say so
Post by d00zah »
Unless I misread, Mike also says so. LibreDrive firmware status
See section "supported - original vendor firmware: 68 firmware(s):"
HL-DT-ST-BD-RE_BU40N-1.00-N003103-211612201528
But MakeMKV's word is usually good enough for me.
spl147
Post by spl147 »
d00zah wrote: Sat Mar 20, 2021 9:14 pm Unless I misread, Mike also says so. LibreDrive firmware status
i guess if the OP wants to run really old firmware then sure, i prefer to use more current firmware as i find 1.02 way more stable for ripping
Post by d00zah »
Fair enough, but that's a different can of worms. W/out change logs, it's hard to tell if a new F/W does more than just implement a new 'unfriendly' measure, or actually improves anything. I prefer to know before recommending out of hand. YMMV People seem a tad "flash-happy" these days. IMO Pax
