Is this drive compatible with LibreDrive?
Manufacturer: Optiarc
Product: BD RW BD-5740H
Revision: 1.50
Serial number: 1039414L121
I am having issues with MakeMKV failing on all DVDs I try to rip. Getting the dreaded 'OS error - (ipc/send) invalid destiantion port' while reading..... error. I added a powered USB hub but still no go. I get the same error on about 10 DVDs I've tried. Haven't tried any Blu-rays yet.
I"m hoping to use LibreDrive parameters to limit the drive speed as that seems to be my issue... At least it seems so.
Optiarc external USB drive
Re: Optiarc external USB drive
i dont think its going to happen its not a drive LD supports.
you can do it by writing to something really slow like an old flash drive
That's what I was afraid of. I wish I would have looked into this before I bought this drive... Can I get a recommendation for a new/used drive that has been shown to work well with MakeMKV and/or LD? I am using a Mac Mini so need an external drive. USB or Thunderbolt.
Any suggestions would be most appreciated. I have a big DVD and BD collection I want to get started on and I'm behind a locked gate at this point.
TIA
Tim.
TIA
Tim.
viewtopic.php?f=16&t=19634
That's a link to the big sticky UHD drives guide. It'll answer all your questions.
