Attempting to flash in macOS
Re: Attempting to flash in macOS
Post by Billycar11 » Tue Jun 02, 2020 12:44 am
dash16 wrote: Tue Jun 02, 2020 12:22 am
I've got the drive connected via a VanTec CB-ST00U3, which apparently won't work for firmware flashing in Windows but I figured I'd try my luck in macOS,
What adapters won't work in windows for flashing won't work in mac os thats why I have that stuff posted.
o-ver
Post by o-ver » Thu Jun 18, 2020 6:13 am
dash16 wrote: Tue Jun 02, 2020 12:22 am I'm considering lugging out an old PC and getting that up and running for a direct SATA connection to the drive simply to firmware flash, but before I tear apart my garage looking for all that mess I figured I'd see if I'm missing something dumb first.
Sorry, I forgot o mention: Flashing did not work with two adaptors laying around. I ordered a USB3.0B-to-USB-C-Cable to flash succesfully direct connected to my MBP!
j_dot
Post by j_dot » Wed Oct 07, 2020 12:22 am
Apologies for bumping an old thread, but I wanted to post a full set of instructions for someone looking to flash a drive on MacOS X:
Start by navigating to the MakeMKV application
cd /Applications/MakeMKV.app/Contents/MacOS
Get the latest SDF file; write it to the local directory (you can also write it to your home directory or someplace more convenient)
curl -O "https://makemkv.com/sdf.bin"
Find the drive identifiers
./makemkvcon f --list
Look for your drive. You should see something like this (in this example, I have two drives attached, each with a disc in; as the first post in the thread points out, though, the /dev/rdisk* won't work):
Found 2 drives(s)
00: /IOBDServices/65961856, /dev/rdisk2, /dev/rdisk2
  PIONEER_BD-RW___BDR-212U_1.00_SFDL000221WL
01: /IOBDServices/C01417F1, /dev/rdisk5, /dev/rdisk5
  HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_KLFK7LA5541
I was looking to flash the WH16NS60, and I had downloaded the latest MK firmware pack, so:
./makemkvcon f -d /IOBDServices/C01417F1 -f sdf.bin rawflash main,enc -i ~/Downloads/mk-firmware-pack-20200720/MK/HL-DT-ST/WH16NS60/HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Note that I needed to use enc because the 1.03 firmware is encrypted; leave that off if your current firmware is unencrypted.
After doing this, and turning my drive off and on just in case, I was able to rip from a UHD disc. (And, for faster reads: https://www.makemkv.com/forum/viewtopic.php?p=93341 )
pmhCH
Post by pmhCH » Sat Oct 10, 2020 11:13 am
Thanks for this fine "how-to-do" ;)
My problem is only, that my drive is not in the patch list, even if is has the status "possible, not yet enabled" in makemkv:
Can anybody help me here? ;)
Samsung 78" (still with 3D), ATV 4k (64Gb) running Infuse, Hue Sync + Sonos "5.1"
Post by Coopervid » Sat Oct 10, 2020 11:38 am
Your drive can not be made UHD compatible. Those must be based on the MT1959 chip.
pmhCH
Post by pmhCH » Sat Oct 10, 2020 11:43 am
Yes, just saw MIke's post about those Samsung drives and mine seems not supported and probably never will be:
So one wonders why it still says "Possible, not yet enabled" in makemkv...
Post by MartyMcNuts » Sat Oct 10, 2020 10:29 pm
pmhCH wrote: Sat Oct 10, 2020 11:43 am Yes, just saw MIke's post about those Samsung drives and mine seems not supported and probably never will be:
It means that someday (now seems unlikely), your drive may support libredrive (but still, it will never be UHD capable!)
aeharding
Post by aeharding » Thu Dec 24, 2020 11:41 pm
j_dot wrote: Wed Oct 07, 2020 12:22 am Apologies for bumping an old thread, but I wanted to post a full set of instructions for someone looking to flash a drive on MacOS X:
Just flashed my LG WH16NS40 on an m1 (arm-based) 2020 Mac Mini with Big Sur 11.1. Couldn't be easier. Cheers! :D
bachelorbob
Post by bachelorbob » Sat Jan 09, 2021 12:46 am
o-ver wrote: Thu May 28, 2020 5:03 pm Extraction of sdf_0000006d.bin to my home directory
HOW did you extract sdf_0000006d.bin? I have sdf.bin. Replacing 'sdf_0000006d.bin' with 'sdf.bin' did not work.
bachelorbob
Post by bachelorbob » Sat Jan 09, 2021 12:51 am
Using this exact command line, except for my personal paths to files (e.g. '/Applications/MakeMKV/firmwares/DE_LG_BU40N_1.00.bin') and drive ID (e.g. '/IOBDServices/82D49293'), I get:
Unable to load sdf.bin
Internal error 0xffffffff
Does anyone have any idea why?!
Post by dcoke22 » Sat Jan 09, 2021 12:54 am
You might try fully qualifying the path to sdf.bin on your system.
I assume you've read this: viewtopic.php?f=4&t=23129
bachelorbob
Post by bachelorbob » Sat Jan 09, 2021 1:01 am
bachelorbob wrote: Sat Jan 09, 2021 12:51 am Does anyone have any idea why?!
I needed the full path to 'sdf.bin'
/Applications/MakeMKV.app/Contents/MacOS/makemkvcon f -d /IOBDServices/82D49293 -f /Applications/MakeMKV/sdf.bin rawflash main,enc -i /Applications/MakeMKV/firmwares/DE_LG_BU40N_1.00.bin
Viola… I thought. Despite getting a result of:
100% Operation finished
Done successfully
…MakeMKV still shows a LibreDrive status of "Possible, not yet enabled"
Help?
bachelorbob
Post by bachelorbob » Sat Jan 09, 2021 1:17 am
Got rid of the "enc" part of the command line. (My drive being quite new, I expected it to be firmware encrypted.)
Viola!
So, it *IS* possible to firmware flash on a Mac (OS X.13.6), without a virtual/boot camp Windows. For the record, my drive was an 'hp HLDS BDRE BU40N' with firmware BW42. It now considers itself an 'HL-DT-ST BD-RE BU40N' with firmware 1.00.
I am staying on FW 1.00 because I use DVDFab to do whole disc copies (.ISO). If anyone knows that DVDFab will work with a later firmware (1.03, 1.04), or a reason to use an MK firmware, please let me know.
bachelorbob
Post by bachelorbob » Sat Jan 09, 2021 6:26 pm
I also successfully flashed my BU40N on a MacBook Pro using this generic, low-quality, low-cost USB3 enclosure from AliExpress:
White-USB3-0-SATA-Optical-Drive-Case-Kit-External-Mobile-Enclosure-Blu-ray-Case-For-Notebook.jpg
bachelorbob
Post by bachelorbob » Fri Jan 15, 2021 5:05 pm
I have successfully copied (to an ISO image) the film '1917' from a UHD disc, using my MacBook Pro mid-2012, an external BU40N flashed to FW 1.00, and DVDFab 11.0.7.5. That said, I never attempted to extract a UHD under the stock FW of BW42. This was the first UHD I had in hand, and it arrived after I downgraded the firmware.
