Volume key is Unknown
SyrimSloane
I keep getting this message and failed to open when trying to rip TOP GUN & KNIVES OUT UHD’s.
I’ve already sent the dumps twice to svq email and still having the issue.
Any fix for this?
Any fix for this?
Re: Volume key is Unknown
When you start a rip with MakeMKV, so you see any messages about not being able to download the latest hash key file?
Do you get sdf download failed or disabled errors?
SyrimSloane
these are the log messages:-
MakeMKV v1.15.4 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/SS/MakeMKV_log.txt
Optical drive "BD-RE ASUS BW-16D1HT 3.10d" opened in OS access mode.
Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
Saved AACS dump file as /Users/SS/Library/MakeMKV/MKB20_v72_Top_Gun_DAD9.tgz
DEBUG: Code 0 at jlaLC{K\#"u''c~5:29396069
DEBUG: Code 0 at jlaLC{K\#"u''c~5:29395149
SyrimSloane
No, just Volume key us unknown and some debug code error.Woodstock wrote:When you start a rip with MakeMKV, so you see any messages about not being able to download the latest hash key file?
SyrimSloane
No sdf errorsBillycar11 wrote:Do you get sdf download failed or disabled errors?
When did you send in the dumps? It can take a week or two (or longer on occasion) for a key to be added.SyrimSloane wrote: Thu Jan 07, 2021 1:19 pm I keep getting this message and failed to open when trying to rip TOP GUN & KNIVES OUT UHD’s.
Any fix for this?
SyrimSloane
Sent on the 21st of last month.MartyMcNuts wrote:When did you send in the dumps? It can take a week or two (or longer on occasion) for a key to be added.SyrimSloane wrote: Thu Jan 07, 2021 1:19 pm I keep getting this message and failed to open when trying to rip TOP GUN & KNIVES OUT UHD’s.
Any fix for this?
I even sent a dump for DUNKIRK on October and I’m still getting the same log error as these two discs.
Try your luck at contacting Mike (owner/developer of MakeMKV) at:
support@makemkv.com
With all error and dump logs and a link to this post to see if he can assist further. He can get very busy at times, but it’s worth a shot.
support@makemkv.com
SyrimSloane
Okay, thanks.st4evr wrote:Try your luck at contacting Mike (owner/developer of MakeMKV) at:
support@makemkv.com
And just to confirm, you do have "Enable Internet access" checked in Tools / Preferences / General?
Using: ASUS BW-16D1HT 3.00
SyrimSloane
Yes, and im using a macbook. Im ripping other discs fine. Its just these three.preserve wrote:And just to confirm, you do have "Enable Internet access" checked in Tools / Preferences / General?
Other UHD discs?SyrimSloane wrote: Fri Jan 08, 2021 1:50 amYes, and im using a macbook. Im ripping other discs fine. Its just these three.preserve wrote:And just to confirm, you do have "Enable Internet access" checked in Tools / Preferences / General?
SyrimSloane
Yes.Billycar11 wrote:Other UHD discs?SyrimSloane wrote: Fri Jan 08, 2021 1:50 amYes, and im using a macbook. Im ripping other discs fine. Its just these three.preserve wrote:And just to confirm, you do have "Enable Internet access" checked in Tools / Preferences / General?
SyrimSloane
I’m starting to get Automatic HK downloading is failed error.
Should i add something under proxy in preferences or leave it blank.
