Volume key is Unknown
SyrimSloane
Post by SyrimSloane »
I keep getting this message and failed to open when trying to rip TOP GUN & KNIVES OUT UHD’s.
I’ve already sent the dumps twice to svq email and still having the issue.
Any fix for this?
Re: Volume key is Unknown
When you start a rip with MakeMKV, so you see any messages about not being able to download the latest hash key file?
Do you get sdf download failed or disabled errors?
SyrimSloane
these are the log messages:-
MakeMKV v1.15.4 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/SS/MakeMKV_log.txt
Optical drive "BD-RE ASUS BW-16D1HT 3.10d" opened in OS access mode.
Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
Saved AACS dump file as /Users/SS/Library/MakeMKV/MKB20_v72_Top_Gun_DAD9.tgz
DEBUG: Code 0 at jlaLC{K\#"u''c~5:29396069
DEBUG: Code 0 at jlaLC{K\#"u''c~5:29395149
SyrimSloane
Woodstock wrote:When you start a rip with MakeMKV, so you see any messages about not being able to download the latest hash key file?
No, just Volume key us unknown and some debug code error.
SyrimSloane
Billycar11 wrote:Do you get sdf download failed or disabled errors?
No sdf errors
SyrimSloane wrote:
Thu Jan 07, 2021 1:19 pm
Any fix for this?
When did you send in the dumps? It can take a week or two (or longer on occasion) for a key to be added.
SyrimSloane
Any fix for this?
Sent on the 21st of last month.
I even sent a dump for DUNKIRK on October and I’m still getting the same log error as these two discs.
st4evr
Post by st4evr »
Try your luck at contacting Mike (owner/developer of MakeMKV) at:
support@makemkv.com
With all error and dump logs and a link to this post to see if he can assist further. He can get very busy at times, but it’s worth a shot.
SyrimSloane
st4evr wrote:Try your luck at contacting Mike (owner/developer of MakeMKV) at:
support@makemkv.com
Okay, thanks.
preserve
Post by preserve »
And just to confirm, you do have "Enable Internet access" checked in Tools / Preferences / General?
Using: ASUS BW-16D1HT 3.00
SyrimSloane
preserve wrote:And just to confirm, you do have "Enable Internet access" checked in Tools / Preferences / General?
Yes, and im using a macbook. Im ripping other discs fine. Its just these three.
SyrimSloane wrote:
Fri Jan 08, 2021 1:50 am
Other UHD discs?
SyrimSloane
Other UHD discs?
Yes.
SyrimSloane
I’m starting to get Automatic HK downloading is failed error.
Should i add something under proxy in preferences or leave it blank.
