shattered Blu-ray disk
wmcclain
#1 Post by wmcclain » Thu Jan 07, 2021 8:36 pm
This is a new one for me.
I started a full disk backup of a standard Blu-ray and left the house. MakeMKV reported errors when I returned. Ejecting the disk it came out in broken fragments, large and small. I fear the drive is ruined, but I'll open up the computer tomorrow to see if more clean up is required.
I presume if I had been at home I would have heard some sort of high speed spin and stopped it.
Here are the details:
ASUS BW-16D1HT 3.10
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL8K15F3522
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.10
Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
Backing up disc into folder "XXX"
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00129.m2ts' at offset '7864320'
Failed to save title /BDMV/STREAM/00129.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00129.m2ts
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00123.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00123.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00123.m2ts
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00015.m2ts' at offset '5898240'
Failed to save title /BDMV/STREAM/00015.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00015.m2ts
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00030.m2ts' at offset '5566464'
Failed to save title /BDMV/STREAM/00030.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00030.m2ts
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00026.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00026.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00026.m2ts
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00127.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00127.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00127.m2ts
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00021.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00021.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00021.m2ts
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00009.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00009.m2ts
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00018.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00018.m2ts
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00098.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00098.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00098.m2ts
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00002.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00002.m2ts
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00000.m2ts to file /home/wmcclain/wem/backup/HARRY_POTTER/BDMV/STREAM/00000.m2ts
Encountered 27 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup done but 12 files failed hash check
st4evr
Re: shattered Blu-ray disk
#2 Post by st4evr » Thu Jan 07, 2021 8:43 pm
This happens, sometimes when drives fail or in some cases when there may be defects on the disc or from disc manufacturing.
Have had it happen to me even 10+ years ago. Not really anything MakeMKV support can do on hardware failures like this. Best bet is to replace the drive as small pieces can or may have already damaged the lasers or other sensitive components within the drive. But you can also try to thoroughly take it apart and clean it to see if you get lucky.
#3 Post by Woodstock » Thu Jan 07, 2021 9:15 pm
It is very possible to get disks with minor cracks that become major. I am VERY cautious about pulling disks out of the boxes when the hub grippers are rigid, because I have one BD (Last Star Fighter) that has a notch in the hub from a too-tight gripper. I avoid ripping that disk, and only use a slow drive (2-3x max) if I have to. I've also received disks from certain rental places that had full-length cracks that were very hard to see.
At the very least, your laser assembly took some hits, perhaps fatal.
If you want to see what it looks like... CD shattering at 170,000 frames per second
