Volume key is Unknown
SyrimSloane
#1 Post by SyrimSloane » Thu Jan 07, 2021 1:19 pm
I keep getting this message and failed to open when trying to rip TOP GUN & KNIVES OUT UHD’s.
I’ve already sent the dumps twice to svq email and still having the issue.
Any fix for this?
Re: Volume key is Unknown
#2 Post by Woodstock » Thu Jan 07, 2021 1:42 pm
When you start a rip with MakeMKV, so you see any messages about not being able to download the latest hash key file?
#3 Post by Billycar11 » Thu Jan 07, 2021 1:43 pm
Do you get sdf download failed or disabled errors?
SyrimSloane
#4 Post by SyrimSloane » Thu Jan 07, 2021 1:51 pm
these are the log messages:-
MakeMKV v1.15.4 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/SS/MakeMKV_log.txt
Optical drive "BD-RE ASUS BW-16D1HT 3.10d" opened in OS access mode.
Using LibreDrive mode (v06.2 id=0FA242DD4D0B)
Saved AACS dump file as /Users/SS/Library/MakeMKV/MKB20_v72_Top_Gun_DAD9.tgz
DEBUG: Code 0 at jlaLC{K\#"u''c~5:29396069
DEBUG: Code 0 at jlaLC{K\#"u''c~5:29395149
SyrimSloane
#5 Post by SyrimSloane » Thu Jan 07, 2021 2:00 pm
Woodstock wrote:When you start a rip with MakeMKV, so you see any messages about not being able to download the latest hash key file?
No, just Volume key us unknown and some debug code error.
SyrimSloane
#6 Post by SyrimSloane » Thu Jan 07, 2021 2:02 pm
Billycar11 wrote:Do you get sdf download failed or disabled errors?
No sdf errors
#7 Post by MartyMcNuts » Thu Jan 07, 2021 11:11 pm
SyrimSloane wrote: Thu Jan 07, 2021 1:19 pm I keep getting this message and failed to open when trying to rip TOP GUN & KNIVES OUT UHD’s.
Any fix for this?
When did you send in the dumps? It can take a week or two (or longer on occasion) for a key to be added.
SyrimSloane
#8 Post by SyrimSloane » Thu Jan 07, 2021 11:31 pm
Any fix for this?
Sent on the 21st of last month.
I even sent a dump for DUNKIRK on October and I’m still getting the same log error as these two discs.
st4evr
#9 Post by st4evr » Fri Jan 08, 2021 12:00 am
Try your luck at contacting Mike (owner/developer of MakeMKV) at:
support@makemkv.com
With all error and dump logs and a link to this post to see if he can assist further. He can get very busy at times, but it’s worth a shot.
SyrimSloane
#10 Post by SyrimSloane » Fri Jan 08, 2021 12:01 am
st4evr wrote:Try your luck at contacting Mike (owner/developer of MakeMKV) at:
support@makemkv.com
Okay, thanks.
preserve
#11 Post by preserve » Fri Jan 08, 2021 1:48 am
And just to confirm, you do have "Enable Internet access" checked in Tools / Preferences / General?
Using: ASUS BW-16D1HT 3.00
SyrimSloane
#12 Post by SyrimSloane » Fri Jan 08, 2021 1:50 am
preserve wrote:And just to confirm, you do have "Enable Internet access" checked in Tools / Preferences / General?
Yes, and im using a macbook. Im ripping other discs fine. Its just these three.
#13 Post by Billycar11 » Fri Jan 08, 2021 3:10 am
SyrimSloane wrote: Fri Jan 08, 2021 1:50 am
Other UHD discs?
SyrimSloane
#14 Post by SyrimSloane » Fri Jan 08, 2021 3:11 am
Other UHD discs?
Yes.
SyrimSloane
#15 Post by SyrimSloane » Thu Jan 14, 2021 10:40 am
I’m starting to get Automatic HK downloading is failed error.
Should i add something under proxy in preferences or leave it blank.
