Host certificate revoked
RedDom
Post by RedDom »
I tried to use this for the first time and got:
"Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive"
does this mean i now have to wait for a new linux build to try again? or is it more permanent for my blueray drive? I have perviously been using the drive successfully with PowerDVD on windows, although i no longer have access to that machine.
thx
RD
Re: Host certificate revoked
Post by mike admin »
Please enable "log debug messages" in preferences, restart the application, open disc again and copy the log (or type "makemkvcon info disc:0" - it will provide the same log to stdout) and post the log here. Thank you.
RedDom
Post by RedDom »
The log is below
~$ makemkvcon info disc:0
Current action: Scanning CD-ROM devices
Current progress - 0% , Total progress - 0%
ERR: FAILURE: code=00000000 src=rd@W't9CJ>E<N^e`>B0^:213130099
001012:000000:0020 FAILURE: Code 0 at rd@W't9CJ>E<N^e`>B0^:213130099
Current progress - 100% , Total progress - 0%
Current progress - 100% , Total progress - 100%
Current progress - 0% , Total progress - 100%
003010:000000:0000 Using direct disc access mode
Current action: Pre-calculating data
Current action: Processing AV clips
Current progress - 32% , Total progress - 0%
Current progress - 32% , Total progress - 5%
Current progress - 61% , Total progress - 5%
Current progress - 61% , Total progress - 9%
Current progress - 64% , Total progress - 9%
Current progress - 64% , Total progress - 10%
Current progress - 67% , Total progress - 10%
Current progress - 85% , Total progress - 10%
Current progress - 85% , Total progress - 13%
Current action: Processing movie playlists
Current progress - 0% , Total progress - 13%
Current progress - 18% , Total progress - 13%
Current progress - 18% , Total progress - 16%
Current progress - 56% , Total progress - 16%
Current progress - 56% , Total progress - 23%
Current progress - 94% , Total progress - 23%
Current progress - 94% , Total progress - 29%
Current action: Decrypting
Current progress - 0% , Total progress - 29%
Current progress - 18% , Total progress - 29%
Current progress - 18% , Total progress - 34%
Current progress - 20% , Total progress - 34%
Current progress - 20% , Total progress - 35%
Current progress - 22% , Total progress - 35%
Current progress - 24% , Total progress - 35%
Current progress - 25% , Total progress - 35%
Current progress - 25% , Total progress - 36%
Current progress - 27% , Total progress - 36%
Current progress - 29% , Total progress - 36%
Current progress - 29% , Total progress - 37%
Current progress - 31% , Total progress - 37%
Current progress - 33% , Total progress - 37%
Current progress - 33% , Total progress - 38%
Current progress - 35% , Total progress - 38%
Current progress - 37% , Total progress - 38%
Current progress - 37% , Total progress - 39%
Current progress - 38% , Total progress - 39%
Current progress - 40% , Total progress - 39%
Current progress - 40% , Total progress - 40%
Current progress - 42% , Total progress - 40%
Current progress - 44% , Total progress - 40%
Current progress - 44% , Total progress - 41%
Current progress - 46% , Total progress - 41%
Current progress - 48% , Total progress - 41%
Current progress - 48% , Total progress - 42%
Current progress - 51% , Total progress - 42%
Current progress - 53% , Total progress - 42%
Current progress - 53% , Total progress - 43%
Current progress - 55% , Total progress - 43%
Current progress - 57% , Total progress - 43%
Current progress - 57% , Total progress - 44%
Current progress - 59% , Total progress - 44%
Current progress - 61% , Total progress - 44%
Current progress - 61% , Total progress - 45%
Current progress - 62% , Total progress - 45%
Current progress - 64% , Total progress - 45%
Current progress - 64% , Total progress - 46%
Current progress - 66% , Total progress - 46%
Current progress - 68% , Total progress - 46%
Current progress - 68% , Total progress - 47%
Current progress - 70% , Total progress - 47%
Current progress - 72% , Total progress - 47%
Current progress - 72% , Total progress - 48%
Current progress - 74% , Total progress - 48%
Current progress - 75% , Total progress - 48%
Current progress - 75% , Total progress - 49%
Current progress - 77% , Total progress - 49%
Current progress - 79% , Total progress - 49%
Current progress - 79% , Total progress - 50%
Current progress - 90% , Total progress - 50%
Current progress - 90% , Total progress - 52%
ERR: FAILURE: code=ffffffff src=_gZu2upPSL]9h*"L&:121262417
ERR: FAILURE: code=00000000 src=<RvyYVOgJ'-/re]A[$:121261727
ERR: FAILURE: code=00000001 src=<RvyYVOgJ'-/re]A[$:121261727
ERR: FAILURE: code=00000002 src=<RvyYVOgJ'-/re]A[$:121261727
ERR: FAILURE: code=00000003 src=<RvyYVOgJ'-/re]A[$:121261727
ERR: FAILURE: code=00000004 src=<RvyYVOgJ'-/re]A[$:121261727
ERR: FAILURE: code=00000002 src=_gZu2upPSL]9h*"L&:29393907
ERR: FAILURE: code=00000000 src=n-vPu@UDIUb"/!pI:29394045
ERR: FAILURE: code=00000000 src=n-vPu@UDIUb"/!pI:213130628
001012:000000:0020 FAILURE: Code 4294967295 at _gZu2upPSL]9h*"L&:121262417
001012:000000:0020 FAILURE: Code 0 at <RvyYVOgJ'-/re]A[$:121261727
001012:000000:0020 FAILURE: Code 1 at <RvyYVOgJ'-/re]A[$:121261727
001012:000000:0020 FAILURE: Code 2 at <RvyYVOgJ'-/re]A[$:121261727
001012:000000:0020 FAILURE: Code 3 at <RvyYVOgJ'-/re]A[$:121261727
001012:000000:0020 FAILURE: Code 4 at <RvyYVOgJ'-/re]A[$:121261727
001012:000000:0020 FAILURE: Code 2 at _gZu2upPSL]9h*"L&:29393907
003311:000000:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003302:000000:0000 The volume key is unknown for this disc - video can't be decrypted
001012:000000:0020 FAILURE: Code 0 at n-vPu@UDIUb"/!pI:29394045
001012:000000:0020 FAILURE: Code 0 at n-vPu@UDIUb"/!pI:213130628
005010:000000:0000 Failed to open disc
Total 0 titles
thx
RD
RedDom
Post by RedDom »
I'm still getting the same error with 1.4.4, any thoughts.
thx
Dom
There are 2 errors happening:
1. Program was unable to change thread priority at one time (this is not critical)
2. When talking to the drive _some_ SCSI commands were rejected by SG driver.
The command in question was first command that transfers data to the drive (SEND_KEY) so I wonder if your system has some kind of permission issue that allows read commands but blocks write ones. What distro are you using? I know it sounds silly but can you try to run the same command "makemkvcon info disc:0" as root and see if it fails? Normally even read-only access to the cdrom device is sufficient to execute all scsi commands but apparently it is not sufficient in your case. If running as root succeeds then try to add yourself to the group that controls access to /dev/cdrom0 (normally it is called "cdrom"). But please provide more details about your system regardless.
RedDom
Post by RedDom »
Will try your suggestions this evening.
I'm running Ubuntu 8.0.4 desktop install.
**Update***
Ran as Sudo and now it works, it looks like a permissions issue on my end, apologies for wasting your time, and thx for a great app.
RD
You're welcome :)
