CardboardPrison
Post
by CardboardPrison » Wed Dec 30, 2020 9:49 pm
Hello everyone. New to this forum and ripping in general so please be patient with me. Recently purchased the WH16NS40 drive and changed the firmware over to WH16NS60. Everything seems to be working smooth, but I am having AV sync issues. My main purpose of using MakeMKV is to rip all my concert BDs/DVDs to digital in order to view through my Plex media server. I've gone through about 5-6 BDs so far, and it seems like every one has slight audio sync problems. It's very obvious with the concert BDs as I you can see the notes being played almost half a second before the audio comes through. I will be running all of these through Handbrake as well to reduce the file size a bit so I'm not sure if that will help. If someone could recommend me some steps to try for such an issue or provide links with guides to this it would be much appreciated. Below is the log generated in case that helps. Please ignore the slow disk warnings as the first one I did I accidentally selected my RAID.
Debug log started at Wed Dec 30 15:15:47 2020 , written by MakeMKV v1.15.4 win(x64-release)
001005:0000 MakeMKV v1.15.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\zaler/MakeMKV_log.txt
WinCdArb=v1.0.0_tiny win(x64-release)
DEBUG: Code 3 at l36L!t.ju1-I5hQj<x_&C<|l:29395310
SDF v07d: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLPK3695539
001011:0000 Using LibreDrive mode (v06.2 id=7FA2657C7667)
005072:0000 Backing up disc into folder "file://X:/Video/backup/Coma Ecliptic Live"
DEBUG: Code 2147483648 at )MlMsgQtKhB02k"5:121264786
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
005070:0080 Backup done
005081:0104 Backup done.
005072:0000 Backing up disc into folder "file://C:/Downloads/MKV Rips/Big Four/THE_BIG_4_LIVE_DISC_1"
005072:0000 Backing up disc into folder "file://C:/Downloads/MKV Rips/Big Four/THE_BIG_4_LIVE_DISC_2"
005072:0000 Backing up disc into folder "file://C:/Downloads/MKV Rips/BLACKLABELSOCIETY"
005072:0000 Backing up disc into folder "file://C:/Downloads/MKV Rips/MEGADETH_RUST_IN_PEACE"
005072:0000 Backing up disc into folder "file://C:/Downloads/MKV Rips/GOJIRA"
Application exited at Wed Dec 30 21:39:40 2020
Post
by dcoke22 » Wed Dec 30, 2020 10:33 pm
The log looks like you're making backups of blu-rays, which is fine. How are you playing these?
berahome
Post
by berahome » Wed Jan 06, 2021 3:59 am
CardboardPrison wrote: Wed Dec 30, 2020 9:49 pm
Hello everyone
Hey, did you solve the problem?
